Ir para o conteúdo principal
LG VX5400 Logic Board Replacement
O que você precisa
  1. LG VX5400 Logic Board Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the cell phone and turn it over on its back side
    Pergunte ao FixBot
    Comentar
  2. LG VX5400 Logic Board Replacement: passo 2, imagem 1 %32
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
    Pergunte ao FixBot
    Comentar
  3. LG VX5400 Logic Board Replacement: passo 3, imagem 1 %32 LG VX5400 Logic Board Replacement: passo 3, imagem 2 %32 LG VX5400 Logic Board Replacement: passo 3, imagem 3 %32
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
    Pergunte ao FixBot
    Comentar
  4. LG VX5400 Logic Board Replacement, Outer Casing: passo 4, imagem 1 %32
    • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
    Pergunte ao FixBot
    Comentar
  5. LG VX5400 Logic Board Replacement: passo 5, imagem 1 %32
    • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
    Pergunte ao FixBot
    Comentar
  6. LG VX5400 Logic Board Replacement, Logic Board: passo 6, imagem 1 %32 LG VX5400 Logic Board Replacement, Logic Board: passo 6, imagem 2 %32
    • While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
    Pergunte ao FixBot
    Comentar
  7. LG VX5400 Logic Board Replacement: passo 7, imagem 1 %32 LG VX5400 Logic Board Replacement: passo 7, imagem 2 %32
    • Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
    Pergunte ao FixBot
    Comentar
Conclusão
Sourabh
Membro desde: 04/15/10
132 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 26-26, Regan Spring 2010 Membro de Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 30
Ao todo: 2,835
