Ir para o conteúdo principal
LG V50 ThinQ Screen Replacement
O que você precisa
  1. LG V50 ThinQ Screen Replacement, Screen: passo 1, imagem 1 %32 LG V50 ThinQ Screen Replacement, Screen: passo 1, imagem 2 %32 LG V50 ThinQ Screen Replacement, Screen: passo 1, imagem 3 %32
    • Flip the phone over, making sure that the back of the phone is facing up.
    • With an opening pick, run the tool along the edge of the back cover of the phone and carefully pry it open.
  2. LG V50 ThinQ Screen Replacement: passo 2, imagem 1 %32 LG V50 ThinQ Screen Replacement: passo 2, imagem 2 %32
    • With the device facing down, remove all 12 1mm Phillips #000 screws.
    • Keep in mind that the screws must be reused at the end of the guide to put the phone back together.
  3. LG V50 ThinQ Screen Replacement: passo 3, imagem 1 %32 LG V50 ThinQ Screen Replacement: passo 3, imagem 2 %32 LG V50 ThinQ Screen Replacement: passo 3, imagem 3 %32
    • Remove the two brackets covering the internal components.
  4. LG V50 ThinQ Screen Replacement: passo 4, imagem 1 %32 LG V50 ThinQ Screen Replacement: passo 4, imagem 2 %32
    • Remove the battery connection from its connector port, located above the battery.
    • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
  5. LG V50 ThinQ Screen Replacement: passo 5, imagem 1 %32
    • With an opening pick (or a similar tool that isn't sharp), run the tool along the edge between the screen and the base of the phone.
    • After the screen is removed from the device, use a 1mm double-sided adhesive along the edges of the phone.
    • Carefully put the replacement screen into place.
Conclusão
Uma outra pessoa concluiu este guia.
Carlos Rivera
Membro desde: 11/03/23
121 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 41
Duração total: 244
