Ir para o conteúdo principal
LG V50 ThinQ Battery Replacement
O que você precisa
  1. LG V50 ThinQ Battery Replacement, Battery: passo 1, imagem 1 %32 LG V50 ThinQ Battery Replacement, Battery: passo 1, imagem 2 %32 LG V50 ThinQ Battery Replacement, Battery: passo 1, imagem 3 %32
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Battery Replacement: passo 2, imagem 1 %32 LG V50 ThinQ Battery Replacement: passo 2, imagem 2 %32 LG V50 ThinQ Battery Replacement: passo 2, imagem 3 %32
    • Remove all twelve 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Battery Replacement: passo 3, imagem 1 %32 LG V50 ThinQ Battery Replacement: passo 3, imagem 2 %32 LG V50 ThinQ Battery Replacement: passo 3, imagem 3 %32
    • Remove the two brackets.
  4. LG V50 ThinQ Battery Replacement: passo 4, imagem 1 %32 LG V50 ThinQ Battery Replacement: passo 4, imagem 2 %32
    • DO NOT attempt to remove the phone battery with a metallic/sharp prying object.
    • Disconnect the battery from the phone by removing the battery connection from the connector port.
    • Remove the battery by prying the underside of the battery and pulling upwards with the opening pick (shown in image 2).
    • Do not be too rough with the battery, as it is easy to dent/break into.
    • Now, place the new battery inside the slot, firmly pressing it into the space against the copper-colored heatsink on the bottom.
Conclusão
3 outras pessoas executaram este guia.
Tanmay Sonawane
Membro desde: 10/30/23
262 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 99
Duração total: 461
