Introdução
Use this guide to replace the headphone jack in your LG V20.
O que você precisa
Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
Remove the back cover.
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Use the flat end of a spudger to disconnect the front camera flex cable.
Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
The second rear camera will come out with the motherboard since it is connected on the other side.
You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
Use an iOpener to loosen the adhesive beneath the headphone jack and its flex cable.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
Uma outra pessoa concluiu este guia.
Um comentário
Jesus christ the bottom on mine is right, leaving it as I have nothing to fix just wanted to clean the ports
