Ir para o conteúdo principal
LG Tribute Motherboard Replacement
O que você precisa
  1. LG Tribute Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG Tribute Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Use the plastic opening tool to pry off the back cover.
    Pergunte ao FixBot
    Comentar
  2. LG Tribute Motherboard Replacement: passo 2, imagem 1 %32
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
    Pergunte ao FixBot
    Comentar
  3. LG Tribute Motherboard Replacement, Mid-panel: passo 3, imagem 1 %32 LG Tribute Motherboard Replacement, Mid-panel: passo 3, imagem 2 %32
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
    Pergunte ao FixBot
    Comentar
  4. LG Tribute Motherboard Replacement: passo 4, imagem 1 %32 LG Tribute Motherboard Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
    Pergunte ao FixBot
    Comentar
  5. LG Tribute Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
    Pergunte ao FixBot
    Comentar
  6. LG Tribute Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 LG Tribute Motherboard Replacement, Motherboard: passo 6, imagem 2 %32 LG Tribute Motherboard Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove SIM card by sliding it out of its housing.
    • Remove the front-facing camera using a plastic opening tool.
    • Remove rear-facing camera using a plastic opening tool.
    • Connect these three components to the new motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
2Comentários do guia
ممكن تشريح بوردة lg ls660
nabeel - Responder Compartilhar
For those that find this guide and are looking to dissasemble an lg tribute 2, Make sure to remove your sim card before romoving the cover that has screws. other than that its the same, but i spent a half hour removing my cover carefully just to find out the sd card had held the cover and motherboard togeather, causing Added risk of damage.
Christian Rolfe - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 4,296
