Ir para o conteúdo principal
LG Tribute HD Flex Cable Replacement
O que você precisa
  1. LG Tribute HD Flex Cable Replacement, Battery and SD Card: passo 1, imagem 1 %32 LG Tribute HD Flex Cable Replacement, Battery and SD Card: passo 1, imagem 2 %32
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    Pergunte ao FixBot
    Comentar
  2. LG Tribute HD Flex Cable Replacement: passo 2, imagem 1 %32 LG Tribute HD Flex Cable Replacement: passo 2, imagem 2 %32
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
    Pergunte ao FixBot
    Comentar
  3. LG Tribute HD Flex Cable Replacement, Flex Cable: passo 3, imagem 1 %32 LG Tribute HD Flex Cable Replacement, Flex Cable: passo 3, imagem 2 %32
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
    Pergunte ao FixBot
    Comentar
  4. LG Tribute HD Flex Cable Replacement: passo 4, imagem 1 %32 LG Tribute HD Flex Cable Replacement: passo 4, imagem 2 %32 LG Tribute HD Flex Cable Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, remove the antenna extender from the bottom.
    Pergunte ao FixBot
    Comentar
  5. LG Tribute HD Flex Cable Replacement: passo 5, imagem 1 %32 LG Tribute HD Flex Cable Replacement: passo 5, imagem 2 %32
    • Using your fingers, remove the mid-frame.
    Pergunte ao FixBot
    Comentar
  6. LG Tribute HD Flex Cable Replacement: passo 6, imagem 1 %32 LG Tribute HD Flex Cable Replacement: passo 6, imagem 2 %32 LG Tribute HD Flex Cable Replacement: passo 6, imagem 3 %32
    • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard.
    • Remove the cameras from the phone.
    Pergunte ao FixBot
    Comentar
  7. LG Tribute HD Flex Cable Replacement: passo 7, imagem 1 %32 LG Tribute HD Flex Cable Replacement: passo 7, imagem 2 %32 LG Tribute HD Flex Cable Replacement: passo 7, imagem 3 %32
    • Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
    Pergunte ao FixBot
    Comentar
  8. LG Tribute HD Flex Cable Replacement: passo 8, imagem 1 %32
    • Disconnect the LCD from the motherboard with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  9. LG Tribute HD Flex Cable Replacement: passo 9, imagem 1 %32 LG Tribute HD Flex Cable Replacement: passo 9, imagem 2 %32
    • Use a plastic opening tool to pry up the motherboard form the display housing.
    • Remove the motherboard from the phone.
    Pergunte ao FixBot
    Comentar
  10. LG Tribute HD Flex Cable Replacement: passo 10, imagem 1 %32 LG Tribute HD Flex Cable Replacement: passo 10, imagem 2 %32
    • Use your fingers to remove the flex cables from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Dhruv Patel
Membro desde: 02/14/18
273 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G3, Nance Spring 2018 Membro de USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Membros
Autoria de 34 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 860
