Introdução
This guide will remove the digitizer and mother board from the display screen, allowing it to be replaced.
O que você precisa
Pull off the back cover from the phone using the groove on the bottom right side.
Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
Work your way around the edge of the phone, gently prying the digitizer off the phone.
5 outras pessoas executaram este guia.
