Ir para o conteúdo principal
LG Thrill 4G Phone Buttons Replacement
O que você precisa
  1. LG Thrill 4G Phone Buttons Replacement, Back Cover Removal: passo 1, imagem 1 %32 LG Thrill 4G Phone Buttons Replacement, Back Cover Removal: passo 1, imagem 2 %32
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
    Pergunte ao FixBot
    Comentar
  2. LG Thrill 4G Phone Buttons Replacement, Battery Removal: passo 2, imagem 1 %32 LG Thrill 4G Phone Buttons Replacement, Battery Removal: passo 2, imagem 2 %32
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
    Pergunte ao FixBot
    Comentar
  3. LG Thrill 4G Phone Buttons Replacement, Screw Removal: passo 3, imagem 1 %32
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
    Pergunte ao FixBot
    Comentar
  4. LG Thrill 4G Phone Buttons Replacement, Speaker Removal: passo 4, imagem 1 %32 LG Thrill 4G Phone Buttons Replacement, Speaker Removal: passo 4, imagem 2 %32
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  5. LG Thrill 4G Phone Buttons Replacement, Buttons: passo 5, imagem 1 %32
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
    Pergunte ao FixBot
    Comentar
  6. LG Thrill 4G Phone Buttons Replacement: passo 6, imagem 1 %32 LG Thrill 4G Phone Buttons Replacement: passo 6, imagem 2 %32 LG Thrill 4G Phone Buttons Replacement: passo 6, imagem 3 %32
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
    Pergunte ao FixBot
    Comentar
  7. LG Thrill 4G Phone Buttons Replacement: passo 7, imagem 1 %32
    • Remove the six Phillips #00 screws within the mid-cover bezel.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team 1-6, Blackwell Winter 2015 Membro de USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 882
