Ir para o conteúdo principal
LG TP 1100 Microphone Replacement
O que você precisa
  1. LG TP 1100 Microphone Replacement, Microphone: passo 1, imagem 1 %32
    • Hold antenna between your fingers and unscrew in a counterclockwise direction.
    Pergunte ao FixBot
    Comentar
  2. LG TP 1100 Microphone Replacement: passo 2, imagem 1 %32
    • You will remove antenna by pulling it in an upward motion away from the socket.
    Pergunte ao FixBot
    Comentar
  3. LG TP 1100 Microphone Replacement: passo 3, imagem 1 %32
    • Turn phone so that the back is facing you.
    Pergunte ao FixBot
    Comentar
  4. LG TP 1100 Microphone Replacement: passo 4, imagem 1 %32
    • Use your thumb to pull the tab in an upward motion to release the battery.
    Pergunte ao FixBot
    Comentar
  5. LG TP 1100 Microphone Replacement: passo 5, imagem 1 %32
    • Hold phone securely in one hand and pull the battery away from the phone with your other hand.
    Pergunte ao FixBot
    Comentar
  6. LG TP 1100 Microphone Replacement: passo 6, imagem 1 %32
    • Use your screwdriver to unscrew the four screws from the back plate.
    Pergunte ao FixBot
    Comentar
  7. LG TP 1100 Microphone Replacement: passo 7, imagem 1 %32
    • Turn phone to the side as indicated in the picture.
    Pergunte ao FixBot
    Comentar
  8. LG TP 1100 Microphone Replacement: passo 8, imagem 1 %32
    • Remove the back cover that you just unscrewed and set aside.
    Pergunte ao FixBot
    Comentar
  9. LG TP 1100 Microphone Replacement: passo 9, imagem 1 %32
    • Open the remaining parts like a book but do not separate the two pieces.
    • Do not tear the tape connecting the two pieces.
    Pergunte ao FixBot
    Comentar
  10. LG TP 1100 Microphone Replacement: passo 10, imagem 1 %32 LG TP 1100 Microphone Replacement: passo 10, imagem 2 %32
    • Rotate the phone so that the circuit board is in the palm of your hand and the part connected with tape hangs behind.
    • Use your opening tool to pry the circuit board from the front cover. Do not let the number pad to fall out.
    Pergunte ao FixBot
    Comentar
  11. LG TP 1100 Microphone Replacement: passo 11, imagem 1 %32
    • To remove the microphone, insert your opening tool under microphone and push upward to pry microphone away from the front cover.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Johnny Inlow
Membro desde: 04/10/10
19 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 27-91, Amido Spring 2010 Membro de Cal Poly, Team 27-91, Amido Spring 2010
CPSU-AMIDO-S10S27G91
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 1,616
