Ir para o conteúdo principal
LG Stylo 2 Plus Rear Camera Replacement
O que você precisa
  1. LG Stylo 2 Plus Rear Camera Replacement, Rear Case: passo 1, imagem 1 %32 LG Stylo 2 Plus Rear Camera Replacement, Rear Case: passo 1, imagem 2 %32 LG Stylo 2 Plus Rear Camera Replacement, Rear Case: passo 1, imagem 3 %32
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
    Pergunte ao FixBot
    Comentar
  2. LG Stylo 2 Plus Rear Camera Replacement, Battery: passo 2, imagem 1 %32 LG Stylo 2 Plus Rear Camera Replacement, Battery: passo 2, imagem 2 %32 LG Stylo 2 Plus Rear Camera Replacement, Battery: passo 2, imagem 3 %32
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
    Pergunte ao FixBot
    Comentar
  3. LG Stylo 2 Plus Rear Camera Replacement, Mid-Frame: passo 3, imagem 1 %32 LG Stylo 2 Plus Rear Camera Replacement, Mid-Frame: passo 3, imagem 2 %32
    • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
    Pergunte ao FixBot
    Comentar
  4. LG Stylo 2 Plus Rear Camera Replacement: passo 4, imagem 1 %32 LG Stylo 2 Plus Rear Camera Replacement: passo 4, imagem 2 %32
    • Insert the metal spudger in the dimple at the base of the cover.
    • Pry upward, removing the mid-frame from the phone.
    Pergunte ao FixBot
    Comentar
  5. LG Stylo 2 Plus Rear Camera Replacement, Rear Camera: passo 5, imagem 1 %32 LG Stylo 2 Plus Rear Camera Replacement, Rear Camera: passo 5, imagem 2 %32 LG Stylo 2 Plus Rear Camera Replacement, Rear Camera: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Flip the cover over to show the rear camera unit in the center of the cover.
    • Using the tweezers, carefully grab the rear camera unit and pull directly upward, removing the unit from the cover housing.
    Pergunte ao FixBot
    Comentar
Conclusão
Noah Kehm
Membro desde: 04/22/19
241 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Membro de UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Membros
Autoria de 21 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Ao todo: 314
