Ir para o conteúdo principal
LG Spectrum Sim/SD Port Replacement
O que você precisa
  1. LG Spectrum Sim/SD Port Replacement, Battery: passo 1, imagem 1 %32 LG Spectrum Sim/SD Port Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
    Pergunte ao FixBot
    Comentar
  2. LG Spectrum Sim/SD Port Replacement: passo 2, imagem 1 %32
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
    Pergunte ao FixBot
    Comentar
  3. LG Spectrum Sim/SD Port Replacement, Sim/SD Port: passo 3, imagem 1 %32 LG Spectrum Sim/SD Port Replacement, Sim/SD Port: passo 3, imagem 2 %32
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
    Pergunte ao FixBot
    Comentar
  4. LG Spectrum Sim/SD Port Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
    Pergunte ao FixBot
    Comentar
  5. LG Spectrum Sim/SD Port Replacement: passo 5, imagem 1 %32
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  6. LG Spectrum Sim/SD Port Replacement: passo 6, imagem 1 %32
    • Hook the plastic opening tool underneath the plate and gently lift it up.
    Pergunte ao FixBot
    Comentar
  7. LG Spectrum Sim/SD Port Replacement: passo 7, imagem 1 %32
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
    Pergunte ao FixBot
    Comentar
Conclusão
Aiman Sallam
Membro desde: 02/10/16
506 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-4, Sullivan Spring 2016 Membro de USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 425
