Ir para o conteúdo principal
LG Spectrum Motherboard Replacement
O que você precisa
  1. LG Spectrum Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG Spectrum Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
    Pergunte ao FixBot
    Comentar
  2. LG Spectrum Motherboard Replacement: passo 2, imagem 1 %32
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
    Pergunte ao FixBot
    Comentar
  3. LG Spectrum Motherboard Replacement, Sim/SD Port: passo 3, imagem 1 %32 LG Spectrum Motherboard Replacement, Sim/SD Port: passo 3, imagem 2 %32
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
    Pergunte ao FixBot
    Comentar
  4. LG Spectrum Motherboard Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
    Pergunte ao FixBot
    Comentar
  5. LG Spectrum Motherboard Replacement: passo 5, imagem 1 %32
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  6. LG Spectrum Motherboard Replacement: passo 6, imagem 1 %32
    • Hook the plastic opening tool underneath the plate and gently lift it up.
    Pergunte ao FixBot
    Comentar
  7. LG Spectrum Motherboard Replacement: passo 7, imagem 1 %32
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
    Pergunte ao FixBot
    Comentar
  8. LG Spectrum Motherboard Replacement, Motherboard: passo 8, imagem 1 %32 LG Spectrum Motherboard Replacement, Motherboard: passo 8, imagem 2 %32
    • Use the plastic opening tool to lift up the connector that holds the camera to the board.
    Pergunte ao FixBot
    Comentar
  9. LG Spectrum Motherboard Replacement: passo 9, imagem 1 %32
    • Pull the camera gently out of its housing in the motherboard with your fingers.
    Pergunte ao FixBot
    Comentar
  10. LG Spectrum Motherboard Replacement: passo 10, imagem 1 %32 LG Spectrum Motherboard Replacement: passo 10, imagem 2 %32
    • Using the plastic opening tool, gently pry up the audio port connector.
    Pergunte ao FixBot
    Comentar
  11. LG Spectrum Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the audio port from the motherboard with either your hand or the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  12. LG Spectrum Motherboard Replacement: passo 12, imagem 1 %32 LG Spectrum Motherboard Replacement: passo 12, imagem 2 %32
    • Detach the two cable connector wires from the motherboard with the plastic opening tool.
    • Detach the remaining five connectors from the phone with the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  13. LG Spectrum Motherboard Replacement: passo 13, imagem 1 %32 LG Spectrum Motherboard Replacement: passo 13, imagem 2 %32
    • Hook the plastic opening tool underneath the motherboard and firmly lift it out of the phone casing.
    Pergunte ao FixBot
    Comentar
Conclusão
Aiman Sallam
Membro desde: 02/10/16
506 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-4, Sullivan Spring 2016 Membro de USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 925
