Ir para o conteúdo principal
LG Refrigerator Ice Maker Blower Assembly Replacement
O que você precisa
  1. LG Refrigerator Ice Maker Blower Assembly Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Ice Maker Blower Assembly Replacement, Open the freezer door: passo 2, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Open the freezer door: passo 2, imagem 2 %32
    • Pull open the freezer door fully.
  3. LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the drawer and bin: passo 3, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the drawer and bin: passo 3, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the drawer and bin: passo 3, imagem 3 %32
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the drawer rail covers: passo 4, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the drawer rail covers: passo 4, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the drawer rail covers: passo 4, imagem 3 %32
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator Ice Maker Blower Assembly Replacement, Reassembly notes: passo 5, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Reassembly notes: passo 5, imagem 2 %32
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the drawer: passo 6, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the drawer: passo 6, imagem 2 %32
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator Ice Maker Blower Assembly Replacement: passo 7, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 7, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 7, imagem 3 %32
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator Ice Maker Blower Assembly Replacement, Release the drawer slides: passo 8, imagem 1 %32
    • Use a Phillips screwdriver to remove the screws securing both left drawer slides.
  9. LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the upper left drawer slide: passo 9, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the upper left drawer slide: passo 9, imagem 2 %32
    • Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
    • Remove the upper left drawer slide.
  10. LG Refrigerator Ice Maker Blower Assembly Replacement, Release lower left drawer slide and reposition it: passo 10, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Release lower left drawer slide and reposition it: passo 10, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Release lower left drawer slide and reposition it: passo 10, imagem 3 %32
    • Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
    • Reposition the lower left drawer slide to gain access to the door switch connector.
  11. LG Refrigerator Ice Maker Blower Assembly Replacement, Disconnect the drawer switch and remove the lower slide: passo 11, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Disconnect the drawer switch and remove the lower slide: passo 11, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Disconnect the drawer switch and remove the lower slide: passo 11, imagem 3 %32
    • Squeeze the door switch connector to release it.
    • Pull the door switch connector down to disconnect it.
    • Remove the lower left drawer slide.
    • If you are removing the freezer evaporator cover, likely only the left-hand slides may need to be removed. In some cases you will need to repeat the previous three steps to remove the right slides as well.
  12. LG Refrigerator Ice Maker Blower Assembly Replacement, Release the ice maker: passo 12, imagem 1 %32
    • Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
  13. LG Refrigerator Ice Maker Blower Assembly Replacement: passo 13, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 13, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 13, imagem 3 %32
    • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
    • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
    • When the tab releases, pull the right front corner of the ice maker down.
  14. LG Refrigerator Ice Maker Blower Assembly Replacement: passo 14, imagem 1 %32
    • Repeat the previous operation on the left side of the ice maker to release it.
  15. LG Refrigerator Ice Maker Blower Assembly Replacement: passo 15, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 15, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 15, imagem 3 %32
    • Grasp the front edge of the ice maker and pull it towards you.
    • Lower the ice maker.
  16. LG Refrigerator Ice Maker Blower Assembly Replacement, Disconnect and remove the ice maker: passo 16, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Disconnect and remove the ice maker: passo 16, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Disconnect and remove the ice maker: passo 16, imagem 3 %32
    • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
    • Remove the ice maker.
  17. LG Refrigerator Ice Maker Blower Assembly Replacement, Remove air return cover: passo 17, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove air return cover: passo 17, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove air return cover: passo 17, imagem 3 %32
    • Pinch the rear portion of the air return cover to release it from the freezer wall.
    • Pull the air return cover outward and remove it.
  18. LG Refrigerator Ice Maker Blower Assembly Replacement, Unfasten the evaporator cover: passo 18, imagem 1 %32
    • Use a Philips screwdriver to remove the screw (or screws) securing the evaporator cover.
  19. LG Refrigerator Ice Maker Blower Assembly Replacement, Reposition the evaporator cover: passo 19, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Reposition the evaporator cover: passo 19, imagem 2 %32
    • Don't try to remove the evaporator cover fully, as It is still connected to the fridge with a number of wires.
    • Grasp the evaporator cover by the air vent openings and pull the top edge toward you.
  20. LG Refrigerator Ice Maker Blower Assembly Replacement: passo 20, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 20, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 20, imagem 3 %32
    • Lift the evaporator cover slightly to release the tabs at the lower edge.
    • Swing the left edge of the evaporator cover toward you and lower it.
  21. LG Refrigerator Ice Maker Blower Assembly Replacement, Disconnect the evaporator cover: passo 21, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Disconnect the evaporator cover: passo 21, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Disconnect the evaporator cover: passo 21, imagem 3 %32
    • Disconnect the electrical connections in the upper left corner of the freezer.
    • Make a note of the locations of the connections for re-installation.
  22. LG Refrigerator Ice Maker Blower Assembly Replacement: passo 22, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 22, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement: passo 22, imagem 3 %32
    • Swing the left edge of the evaporator cover further toward you to access the connections in the upper right corner.
    • Squeeze and pull the connector to disconnect the thermistor mounted in the evaporator cover.
  23. LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the evaporator cover: passo 23, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the evaporator cover: passo 23, imagem 2 %32
    • Remove the evaporator cover.
  24. LG Refrigerator Ice Maker Blower Assembly Replacement, Unfasten the ice maker blower: passo 24, imagem 1 %32
    • Use a Phillips screwdriver to remove the screws securing the ice maker blower to the evaporator cover.
  25. LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the ice maker blower: passo 25, imagem 1 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the ice maker blower: passo 25, imagem 2 %32 LG Refrigerator Ice Maker Blower Assembly Replacement, Remove the ice maker blower: passo 25, imagem 3 %32
    • Lift the ice maker blower out of the evaporator cover and remove it.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
38.497 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.613 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 40
Últimos 30 dias: 179
Ao todo: 4,651
