Ir para o conteúdo principal
LG Refrigerator Ice Auger Motor Run Capacitor Replacement
O que você precisa
  1. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Unfasten the control board cover: passo 2, imagem 1 %32
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  3. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the control board cover: passo 3, imagem 1 %32 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the control board cover: passo 3, imagem 2 %32 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the control board cover: passo 3, imagem 3 %32
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the wiring harness: passo 4, imagem 1 %32 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the wiring harness: passo 4, imagem 2 %32 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the wiring harness: passo 4, imagem 3 %32
    • Squeeze and pull the connectors to disconnect them:
    • Connectors from the control board
    • Connectors from the refrigerator
    • Some connectors can remain connected as the wires attached to them don't get in the way. There is no harm if they are disconnected. Remember to reconnect them if disconnected.
  5. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Reposition the wiring harness: passo 5, imagem 1 %32 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Reposition the wiring harness: passo 5, imagem 2 %32
    • Reposition the wiring harness away from the capacitor.
  6. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the capacitor: passo 6, imagem 1 %32 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the capacitor: passo 6, imagem 2 %32 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Disconnect the capacitor: passo 6, imagem 3 %32
    • Pull the two connectors straight off the capacitor to disconnect it.
    • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
    • Information on capacitor safety.
  7. LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the capacitor: passo 7, imagem 1 %32 LG Refrigerator Ice Auger Motor Run Capacitor Replacement, Remove the capacitor: passo 7, imagem 2 %32
    • Use a Phillips screwdriver to remove the screw securing the capacitor to the refrigerator.
    • Remove the capacitor.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
30.695 Reputação
Autoria de 213 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.894 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 123
