Introdução
Use this guide to replace the freezer ice maker on your LG refrigerator.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The freezer ice maker provides a supply of ice stored in your freezer drawer.
When the freezer ice maker malfunctions, you will not have ice available in the ice bucket in the freezer drawer.
O que você precisa
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Lift and remove the upper pull-out drawer.
Lift and remove the main drawer bin.
Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
Lift the cover off of the rail and remove it.
Repeat this procedure for the left drawer rail cover.
Hold the drawer rail cover flush against the side of the drawer rail.
Push the rail cover straight downward to install. It should click into place.
Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
Remove the ice maker.
