Ir para o conteúdo principal
LG Refrigerator Freezer Drawer Switch Testing and Replacement
O que você precisa
  1. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Open the freezer door: passo 2, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Open the freezer door: passo 2, imagem 2 %32
    • Pull open the freezer door fully.
  3. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the drawer and bin: passo 3, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the drawer and bin: passo 3, imagem 2 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the drawer and bin: passo 3, imagem 3 %32
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the drawer rail covers: passo 4, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the drawer rail covers: passo 4, imagem 2 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the drawer rail covers: passo 4, imagem 3 %32
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Reassembly notes: passo 5, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Reassembly notes: passo 5, imagem 2 %32
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the drawer: passo 6, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the drawer: passo 6, imagem 2 %32
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator Freezer Drawer Switch Testing and Replacement: passo 7, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement: passo 7, imagem 2 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement: passo 7, imagem 3 %32
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Release the drawer slides: passo 8, imagem 1 %32
    • Use a Phillips screwdriver to remove the screws securing both left drawer slides.
  9. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the upper left drawer slide: passo 9, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the upper left drawer slide: passo 9, imagem 2 %32
    • Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
    • Remove the upper left drawer slide.
  10. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Release lower left drawer slide and reposition it: passo 10, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Release lower left drawer slide and reposition it: passo 10, imagem 2 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Release lower left drawer slide and reposition it: passo 10, imagem 3 %32
    • Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
    • Reposition the lower left drawer slide to gain access to the door switch connector.
  11. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Disconnect the drawer switch and remove the lower slide: passo 11, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Disconnect the drawer switch and remove the lower slide: passo 11, imagem 2 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Disconnect the drawer switch and remove the lower slide: passo 11, imagem 3 %32
    • Squeeze the door switch connector to release it.
    • Pull the door switch connector down to disconnect it.
    • Remove the lower left drawer slide.
    • If you are removing the freezer evaporator cover, likely only the left-hand slides may need to be removed. In some cases you will need to repeat the previous three steps to remove the right slides as well.
  12. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Test the door switch: passo 12, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Test the door switch: passo 12, imagem 2 %32
    • If you have a multimeter, you can test the freezer door switch for continuity.
    • Set the multimeter to the ohm setting.
    • Check continuity between the two orange wire terminals on the connector.
    • The switch should show less than one ohm resistance in the unpressed position.
    • When pressed, the switch should show no connection.
    • If your switch does not function as described above, follow the next steps to remove and replace it.
  13. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the door switch: passo 13, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the door switch: passo 13, imagem 2 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Remove the door switch: passo 13, imagem 3 %32
    • Press the retaining tab on the switch to release it from the drawer slide assembly.
    • When it is released, push the switch down through the mounting cutout.
    • Remove the switch from the drawer slide assembly.
  14. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Release the wiring from the door switch: passo 14, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Release the wiring from the door switch: passo 14, imagem 2 %32
    • Use a spudger to release the two clips that secure the wiring connector to the door switch.
  15. LG Refrigerator Freezer Drawer Switch Testing and Replacement, Disconnect the wiring harness from the drawer switch: passo 15, imagem 1 %32 LG Refrigerator Freezer Drawer Switch Testing and Replacement, Disconnect the wiring harness from the drawer switch: passo 15, imagem 2 %32
    • Pull the connector straight off the drawer switch to disconnect it.
    • Disconnecting this connector may require considerable force.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
38.497 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.611 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 89
Ao todo: 1,489
