Introdução
Use this guide to replace the evaporator fan on your LG refrigerator.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The evaporator fan is an important part of the cooling system of your refrigerator. It circulates the air inside the refrigerator so that all parts are cooled by the cold air from the evaporator.
If the evaporator fan fails either due to mechanical or electrical failure or cannot turn because of ice buildup, the refrigerator will not stay as cold. This is especially true in the fresh food compartment, as the fan sends cold air to that compartment.
O que você precisa
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Lift and remove the upper pull-out drawer.
Lift and remove the main drawer bin.
Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
Lift the cover off of the rail and remove it.
Repeat this procedure for the left drawer rail cover.
Hold the drawer rail cover flush against the side of the drawer rail.
Push the rail cover straight downward to install. It should click into place.
Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
Use a Phillips screwdriver to remove the screws securing both left drawer slides.
Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
Remove the upper left drawer slide.
Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
Reposition the lower left drawer slide to gain access to the door switch connector.
Squeeze the door switch connector to release it.
Pull the door switch connector down to disconnect it.
Remove the lower left drawer slide.
Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
Remove the ice maker.
Pinch the rear portion of the air return cover to release it from the freezer wall.
Pull the air return cover outward and remove it.
Use a Philips screwdriver to remove the screw (or screws) securing the evaporator cover.
Grasp the evaporator cover by the air vent openings and pull the top edge toward you.
Disconnect the electrical connections in the upper left corner of the freezer.
Use a Philips screwdriver to remove the screws securing the evaporator fan assembly to the evaporator cover.
Remove the evaporator fan assembly.
Insert two flat-head screwdrivers through the top of the fan opening in the fan assembly.
Use the screwdrivers to pry the fan off the shaft.
Remove the fan.
Cut any cable ties securing the motor wires to the evaporator fan assembly.
Unhook the motor wires from the evaporator fan assembly.
