Ir para o conteúdo principal
LG Refrigerator Compressor Run Capacitor Replacement
O que você precisa
  1. LG Refrigerator Compressor Run Capacitor Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Compressor Run Capacitor Replacement, Unfasten the control board cover: passo 2, imagem 1 %32
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  3. LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: passo 3, imagem 1 %32 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: passo 3, imagem 2 %32 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: passo 3, imagem 3 %32
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: passo 4, imagem 1 %32 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: passo 4, imagem 2 %32 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: passo 4, imagem 3 %32
    • Pull the left edge of the capacitor toward you to unclip it.
    • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
    • For information on capacitor safety, click here.
  5. LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: passo 5, imagem 1 %32 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: passo 5, imagem 2 %32 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: passo 5, imagem 3 %32
    • Pull the connector straight off the capacitor to disconnect it.
    • Remove the capacitor.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro desde: 06/30/22
38.497 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 105
Ao todo: 2,466
