Ir para o conteúdo principal
LG Realm Motherboard Replacement
O que você precisa
  1. LG Realm Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG Realm Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
    Pergunte ao FixBot
    Comentar
  2. LG Realm Motherboard Replacement: passo 2, imagem 1 %32
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
    Pergunte ao FixBot
    Comentar
  3. LG Realm Motherboard Replacement, Plastic Midframe: passo 3, imagem 1 %32 LG Realm Motherboard Replacement, Plastic Midframe: passo 3, imagem 2 %32
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
    Pergunte ao FixBot
    Comentar
  4. LG Realm Motherboard Replacement: passo 4, imagem 1 %32
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
    Pergunte ao FixBot
    Comentar
  5. LG Realm Motherboard Replacement, Rear Facing Camera: passo 5, imagem 1 %32
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
    Pergunte ao FixBot
    Comentar
  6. LG Realm Motherboard Replacement: passo 6, imagem 1 %32
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
    Pergunte ao FixBot
    Comentar
  7. LG Realm Motherboard Replacement, Front Facing Camera: passo 7, imagem 1 %32
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
    Pergunte ao FixBot
    Comentar
  8. LG Realm Motherboard Replacement: passo 8, imagem 1 %32
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
    Pergunte ao FixBot
    Comentar
  9. LG Realm Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    • Locate where the motherboard connects to the orange sisterboard. Using the plastic opening tool, disconnect the connection between the phone and the orange ribbon cable.
    Pergunte ao FixBot
    Comentar
  10. LG Realm Motherboard Replacement: passo 10, imagem 1 %32 LG Realm Motherboard Replacement: passo 10, imagem 2 %32
    • Locate the ribbon cables in the top right corner of the motherboard. Using the plastic opening tool, remove the ribbon cables from phone.
    Pergunte ao FixBot
    Comentar
  11. LG Realm Motherboard Replacement: passo 11, imagem 1 %32
    • Using the plastic opening tool, disconnect the ribbon cable that connects the antenna to the motherboard.
    Pergunte ao FixBot
    Comentar
  12. LG Realm Motherboard Replacement: passo 12, imagem 1 %32
    • Using the plastic opening tool, carefully remove the motherboard from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Marist, Team 1-5, Laflen Spring 2016 Membro de Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 1,555
