Ir para o conteúdo principal
LG Power Screen Replacement
O que você precisa
  1. LG Power Screen Replacement, Battery: passo 1, imagem 1 %32 LG Power Screen Replacement, Battery: passo 1, imagem 2 %32
    • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
    • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
    Pergunte ao FixBot
    Comentar
  2. LG Power Screen Replacement: passo 2, imagem 1 %32 LG Power Screen Replacement: passo 2, imagem 2 %32
    • Carefully pop the back panel off and place it to the side.
    Pergunte ao FixBot
    Comentar
  3. LG Power Screen Replacement: passo 3, imagem 1 %32 LG Power Screen Replacement: passo 3, imagem 2 %32
    • Use the thumb tab to remove the battery.
    Pergunte ao FixBot
    Comentar
  4. LG Power Screen Replacement, Motherboard: passo 4, imagem 1 %32
    • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
    Pergunte ao FixBot
    Comentar
  5. LG Power Screen Replacement: passo 5, imagem 1 %32 LG Power Screen Replacement: passo 5, imagem 2 %32
    • Slide a plastic opening tool between the mid and front panel to remove the middle panel.
    • Place the mid panel to the side.
    Pergunte ao FixBot
    Comentar
  6. LG Power Screen Replacement: passo 6, imagem 1 %32 LG Power Screen Replacement: passo 6, imagem 2 %32 LG Power Screen Replacement: passo 6, imagem 3 %32
    • Detach the motherboard and touchscreen from each other by using a plastic opening tool.
    • The motherboard will then be free from the phone.
    Pergunte ao FixBot
    Comentar
  7. LG Power Screen Replacement, Screen: passo 7, imagem 1 %32 LG Power Screen Replacement, Screen: passo 7, imagem 2 %32 LG Power Screen Replacement, Screen: passo 7, imagem 3 %32
    • After removing the motherboard, slide a thin plastic opening tool between the screen and the frame.
    • This step may take awhile, because of the glue keeping the frame and screen together.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Nadia Wilson
Membro desde: 02/09/16
925 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 4-6, Lacy Spring 2016 Membro de USF Tampa, Team 4-6, Lacy Spring 2016
USFT-LACY-S16S4G6
4 Membros
Autoria de 15 guias
9Comentários do guia
do i need a replacement screen?
jj - Responder Compartilhar
My screen is shattered otherwise the phone works fine..touch works and screen under glass is good. I want to replace the screen myself but my question is are the screen and digitizer fused (one piece) or can I just replace the glass screen? For an LG power x
Nikki - Responder Compartilhar
Did you ever figure out if there the same or separate. I'm needing to do the same.
sarahelizabeth0526 - Responder Compartilhar
Where do I buy the glass panel?
Liam McBride - Responder Compartilhar
i got the glass screen at amazonbot most digitisers have a ribbon wire to connecttheres doesnt..not sure if its just held on with 2 face tape??
Peter Maggiop - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 35
Ao todo: 26,654
