Ir para o conteúdo principal
LG Phoenix 2 Screen Replacement
O que você precisa
  1. LG Phoenix 2 Screen Replacement, Battery: passo 1, imagem 1 %32 LG Phoenix 2 Screen Replacement, Battery: passo 1, imagem 2 %32 LG Phoenix 2 Screen Replacement, Battery: passo 1, imagem 3 %32
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
    Pergunte ao FixBot
    Comentar
  2. LG Phoenix 2 Screen Replacement: passo 2, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 2, imagem 2 %32 LG Phoenix 2 Screen Replacement: passo 2, imagem 3 %32
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
    Pergunte ao FixBot
    Comentar
  3. LG Phoenix 2 Screen Replacement, Rear Camera: passo 3, imagem 1 %32 LG Phoenix 2 Screen Replacement, Rear Camera: passo 3, imagem 2 %32
    • Locate the SIM card in the top right corner on the back of the phone.
    • Remove the SIM card by pushing it with your thumb from left to right.
    Pergunte ao FixBot
    Comentar
  4. LG Phoenix 2 Screen Replacement: passo 4, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 4, imagem 2 %32 LG Phoenix 2 Screen Replacement: passo 4, imagem 3 %32
    • Remove all 9 screws on the back by using a Phillips head #00 screwdriver.
    • To remove the screws rotate them counterclockwise.
    Pergunte ao FixBot
    Comentar
  5. LG Phoenix 2 Screen Replacement: passo 5, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 5, imagem 2 %32 LG Phoenix 2 Screen Replacement: passo 5, imagem 3 %32
    • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
    • Pry the bottom shield to separate it from the phone.
    • Once it is loose you should be able to remove it with your hand.
    Pergunte ao FixBot
    Comentar
  6. LG Phoenix 2 Screen Replacement: passo 6, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 6, imagem 2 %32 LG Phoenix 2 Screen Replacement: passo 6, imagem 3 %32
    • Insert the flat end of the Spudger between the screen and the chromed frame.
    • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
    Pergunte ao FixBot
    Comentar
  7. LG Phoenix 2 Screen Replacement: passo 7, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 7, imagem 2 %32 LG Phoenix 2 Screen Replacement: passo 7, imagem 3 %32
    • Insert the flat end of the Spudger or the plastic opening tool underneath the camera connector.
    • Gently lever the camera connector free.
    • Once disconnected, take the camera out.
    Pergunte ao FixBot
    Comentar
  8. LG Phoenix 2 Screen Replacement: passo 8, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 8, imagem 2 %32 LG Phoenix 2 Screen Replacement: passo 8, imagem 3 %32
    • The front camera can be removed in a similar way as the rear camera. See previous step.
    Pergunte ao FixBot
    Comentar
  9. LG Phoenix 2 Screen Replacement, Screen: passo 9, imagem 1 %32 LG Phoenix 2 Screen Replacement, Screen: passo 9, imagem 2 %32 LG Phoenix 2 Screen Replacement, Screen: passo 9, imagem 3 %32
    • Remove the speaker using the Spudger.
    Pergunte ao FixBot
    Comentar
  10. LG Phoenix 2 Screen Replacement: passo 10, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 10, imagem 2 %32 LG Phoenix 2 Screen Replacement: passo 10, imagem 3 %32
    • Remove the screen connector using the Spudger.
    Pergunte ao FixBot
    Comentar
  11. LG Phoenix 2 Screen Replacement: passo 11, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 11, imagem 2 %32
    • Using a Spudger, separate the motherboard from the back frame.
    Pergunte ao FixBot
    Comentar
  12. LG Phoenix 2 Screen Replacement: passo 12, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 12, imagem 2 %32
    • Heat the screen up using a heat gun (or the IOpener) to loosen up the screen. The heat gun needs to be moved around the edges of the phone in order to equally heat the edges.
    Pergunte ao FixBot
    Comentar
  13. LG Phoenix 2 Screen Replacement: passo 13, imagem 1 %32 LG Phoenix 2 Screen Replacement: passo 13, imagem 2 %32 LG Phoenix 2 Screen Replacement: passo 13, imagem 3 %32
    • Pick the Jimmy and slide it's blade around the edge of the screen.
    • Separate the screen from the frame.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S2-G2, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S2G2
4 Membros
Autoria de 10 guias
2Comentários do guia
Works for the Phoenix 3 as well but I wouldn’t try taking out the rear facing camera. You shouldn’t have to either way.
dtcarani - Responder Compartilhar
“Works for the Phoenix 3 as well but I wouldn’t try taking out the rear facing camera. You shouldn’t have to either way” -dtcarani
Thank you dtcarani it absolutely does work for the Phoenix 3.
And, I did not need to remove the rear facing camera.
John Faires - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 43
Ao todo: 5,488
