Ir para o conteúdo principal
LG Phoenix 2 Camera Replacement
O que você precisa
  1. LG Phoenix 2 Camera Replacement, Battery: passo 1, imagem 1 %32 LG Phoenix 2 Camera Replacement, Battery: passo 1, imagem 2 %32 LG Phoenix 2 Camera Replacement, Battery: passo 1, imagem 3 %32
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
    Pergunte ao FixBot
    Comentar
  2. LG Phoenix 2 Camera Replacement: passo 2, imagem 1 %32 LG Phoenix 2 Camera Replacement: passo 2, imagem 2 %32 LG Phoenix 2 Camera Replacement: passo 2, imagem 3 %32
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
    Pergunte ao FixBot
    Comentar
  3. LG Phoenix 2 Camera Replacement, Rear Camera: passo 3, imagem 1 %32 LG Phoenix 2 Camera Replacement, Rear Camera: passo 3, imagem 2 %32
    • Locate the SIM card in the top right corner on the back of the phone.
    • Remove the SIM card by pushing it with your thumb from left to right.
    Pergunte ao FixBot
    Comentar
  4. LG Phoenix 2 Camera Replacement: passo 4, imagem 1 %32 LG Phoenix 2 Camera Replacement: passo 4, imagem 2 %32 LG Phoenix 2 Camera Replacement: passo 4, imagem 3 %32
    • Remove all 9 screws on the back by using a Phillips head #00 screwdriver.
    • To remove the screws rotate them counterclockwise.
    Pergunte ao FixBot
    Comentar
  5. LG Phoenix 2 Camera Replacement: passo 5, imagem 1 %32 LG Phoenix 2 Camera Replacement: passo 5, imagem 2 %32 LG Phoenix 2 Camera Replacement: passo 5, imagem 3 %32
    • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
    • Pry the bottom shield to separate it from the phone.
    • Once it is loose you should be able to remove it with your hand.
    Pergunte ao FixBot
    Comentar
  6. LG Phoenix 2 Camera Replacement: passo 6, imagem 1 %32 LG Phoenix 2 Camera Replacement: passo 6, imagem 2 %32 LG Phoenix 2 Camera Replacement: passo 6, imagem 3 %32
    • Insert the flat end of the Spudger between the screen and the chromed frame.
    • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
    Pergunte ao FixBot
    Comentar
  7. LG Phoenix 2 Camera Replacement: passo 7, imagem 1 %32 LG Phoenix 2 Camera Replacement: passo 7, imagem 2 %32 LG Phoenix 2 Camera Replacement: passo 7, imagem 3 %32
    • Insert the flat end of the Spudger or the plastic opening tool underneath the camera connector.
    • Gently lever the camera connector free.
    • Once disconnected, take the camera out.
    Pergunte ao FixBot
    Comentar
  8. LG Phoenix 2 Camera Replacement: passo 8, imagem 1 %32 LG Phoenix 2 Camera Replacement: passo 8, imagem 2 %32 LG Phoenix 2 Camera Replacement: passo 8, imagem 3 %32
    • The front camera can be removed in a similar way as the rear camera. See previous step.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team S2-G2, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S2G2
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 41
Ao todo: 995
