Ir para o conteúdo principal
LG Optimus T Screen Replacement
O que você precisa
  1. LG Optimus T Screen Replacement, Screen: passo 1, imagem 1 %32 LG Optimus T Screen Replacement, Screen: passo 1, imagem 2 %32 LG Optimus T Screen Replacement, Screen: passo 1, imagem 3 %32
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using the plastic opening tool to remove the phone’s back cover. At the top of the phone, there’s an indentation to put the tool into to pop the case off.
    Pergunte ao FixBot
    Comentar
  2. LG Optimus T Screen Replacement: passo 2, imagem 1 %32
    • Remove the battery. There’s an indentation to the left of the camera lens.
    Pergunte ao FixBot
    Comentar
  3. LG Optimus T Screen Replacement: passo 3, imagem 1 %32
    • Remove the six (6), J0 Phillip's head, 4.5mm screws.
    • Be sure to retain all screws for reassembly.
    Pergunte ao FixBot
    Comentar
  4. LG Optimus T Screen Replacement: passo 4, imagem 1 %32 LG Optimus T Screen Replacement: passo 4, imagem 2 %32
    • Remove interior case. There are indentations on the top and bottom of the phone. Using a spudger, remove the interior case.
    • You might have difficulty popping the interior case off, and a more durable prying device may be needed.
    Pergunte ao FixBot
    Comentar
  5. LG Optimus T Screen Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Pull up connector tab
    • Connector tabs may be difficult to remove, and tweezers may be required to assist removal.
    Pergunte ao FixBot
    Comentar
  6. LG Optimus T Screen Replacement: passo 6, imagem 1 %32 LG Optimus T Screen Replacement: passo 6, imagem 2 %32
    • Remove SD card mount. Use a plastic opening tool to assist removal.
    Pergunte ao FixBot
    Comentar
  7. LG Optimus T Screen Replacement: passo 7, imagem 1 %32
    • Use a J0 screwdriver to remove two 1.8mm screws from the charging port.
    • Charging port and motherboard are connected.
    Pergunte ao FixBot
    Comentar
  8. LG Optimus T Screen Replacement: passo 8, imagem 1 %32 LG Optimus T Screen Replacement: passo 8, imagem 2 %32
    • Remove connector tab. Then remove the motherboard.
    Pergunte ao FixBot
    Comentar
  9. LG Optimus T Screen Replacement: passo 9, imagem 1 %32 LG Optimus T Screen Replacement: passo 9, imagem 2 %32
    • Using a spudger, gently pry off the metal panel on the back of the screen attached by 4 retaining points.
    • Remove the screen from the front of your device.
    Pergunte ao FixBot
    Comentar
Conclusão
Edward Farris
Membro desde: 02/07/17
112 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-3, Wilder Spring 2017 Membro de Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 398
