Ir para o conteúdo principal
LG Optimus G Pro Battery Replacement
O que você precisa
  1. LG Optimus G Pro Battery Replacement, Remove Back Cover.: passo 1, imagem 1 %32
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
    Pergunte ao FixBot
    Comentar
  2. LG Optimus G Pro Battery Replacement, Remove the Battery.: passo 2, imagem 1 %32
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
Wesley Pate
Membro desde: 09/25/14
1.641 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 15-5, Remmell Fall 2014 Membro de USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 3,530
