Ir para o conteúdo principal
LG Optimus F60 Front Camera Replacement
O que você precisa
  1. LG Optimus F60 Front Camera Replacement, Battery: passo 1, imagem 1 %32 LG Optimus F60 Front Camera Replacement, Battery: passo 1, imagem 2 %32 LG Optimus F60 Front Camera Replacement, Battery: passo 1, imagem 3 %32
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
    Pergunte ao FixBot
    Comentar
  2. LG Optimus F60 Front Camera Replacement: passo 2, imagem 1 %32 LG Optimus F60 Front Camera Replacement: passo 2, imagem 2 %32 LG Optimus F60 Front Camera Replacement: passo 2, imagem 3 %32
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
    Pergunte ao FixBot
    Comentar
  3. LG Optimus F60 Front Camera Replacement, Front Camera: passo 3, imagem 1 %32 LG Optimus F60 Front Camera Replacement, Front Camera: passo 3, imagem 2 %32
    • Use the phillips #000 Screwdriver to unscrew eight 4mm screws.
    Pergunte ao FixBot
    Comentar
  4. LG Optimus F60 Front Camera Replacement: passo 4, imagem 1 %32 LG Optimus F60 Front Camera Replacement: passo 4, imagem 2 %32
    • Insert the plastic opening tool in the indentation marked by the red square.
    • Pry the plastic opening tool upwards to release the lower back panel.
    • Remove the lower back panel from the device.
    Pergunte ao FixBot
    Comentar
  5. LG Optimus F60 Front Camera Replacement: passo 5, imagem 1 %32 LG Optimus F60 Front Camera Replacement: passo 5, imagem 2 %32 LG Optimus F60 Front Camera Replacement: passo 5, imagem 3 %32
    • Continue moving plastic opening tool around device until back panel is loose enough to remove.
    Pergunte ao FixBot
    Comentar
  6. LG Optimus F60 Front Camera Replacement: passo 6, imagem 1 %32 LG Optimus F60 Front Camera Replacement: passo 6, imagem 2 %32 LG Optimus F60 Front Camera Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Locate the digitizer connection on the lower left hand side of the device.
    • Use the tweezers to lift up and gently remove the connector.
    Pergunte ao FixBot
    Comentar
  7. LG Optimus F60 Front Camera Replacement: passo 7, imagem 1 %32 LG Optimus F60 Front Camera Replacement: passo 7, imagem 2 %32 LG Optimus F60 Front Camera Replacement: passo 7, imagem 3 %32
    • Locate the front camera on the upper left hand side of the device. The camera is marked in red.
    • Use the tweezers to remove the front camera from the connector marked in orange.
    • Remove and replace front camera.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 474
