Ir para o conteúdo principal
LG Optimus F3 Charging port unit Replacement
O que você precisa
  1. LG Optimus F3 Charging port unit  Replacement, Motherboard: passo 1, imagem 1 %32
    • Turn the device so that the back faces up.
    • It is easiest to open the case near the charging port located at the bottom of the phone.
    • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
    Pergunte ao FixBot
    Comentar
  2. LG Optimus F3 Charging port unit  Replacement: passo 2, imagem 1 %32
    • With back case removed, the battery is visible. The battery is the large square object.
    • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
    Pergunte ao FixBot
    Comentar
  3. LG Optimus F3 Charging port unit  Replacement: passo 3, imagem 1 %32
    • Remove 10 1.0 mm screws located on the back of the device.
    • Refer to the outlined locations in the image for the screws.
    Pergunte ao FixBot
    Comentar
  4. LG Optimus F3 Charging port unit  Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to separate the inner case from the device.
    • Wedge the plastic opening tool between the case.
    • Wiggle the tool and use leverage to pry the case apart.
    Pergunte ao FixBot
    Comentar
  5. LG Optimus F3 Charging port unit  Replacement: passo 5, imagem 1 %32
    • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
    • Use the plastic opening tool to separate the camera from the motherboard.
    • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
    Pergunte ao FixBot
    Comentar
  6. LG Optimus F3 Charging port unit  Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to disconnect and remove the rear facing camera.
    Pergunte ao FixBot
    Comentar
  7. LG Optimus F3 Charging port unit  Replacement: passo 7, imagem 1 %32
    • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Note that the sim card and the memory card connector are one unit.
    • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
    Pergunte ao FixBot
    Comentar
  8. LG Optimus F3 Charging port unit  Replacement: passo 8, imagem 1 %32
    • Use the plastic opening tool to remove the charging port unit.
    • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
    Pergunte ao FixBot
    Comentar
  9. LG Optimus F3 Charging port unit  Replacement: passo 9, imagem 1 %32
    • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • The motherboard is an L-shaped unit above and to the left of the battery encasement.
    • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
    Pergunte ao FixBot
    Comentar
  10. LG Optimus F3 Charging port unit  Replacement, Charging port unit: passo 10, imagem 1 %32
    • Remove one 1.0 mm screw.
    Pergunte ao FixBot
    Comentar
  11. LG Optimus F3 Charging port unit  Replacement: passo 11, imagem 1 %32
    • Use a plastic opening tool to remove front glass protector.
    Pergunte ao FixBot
    Comentar
  12. LG Optimus F3 Charging port unit  Replacement: passo 12, imagem 1 %32
    • Use the plastic opening tool to remove front glass cover carefully. Try not to break the connector.
    Pergunte ao FixBot
    Comentar
  13. LG Optimus F3 Charging port unit  Replacement: passo 13, imagem 1 %32
    • Remove the front facing camera.
    Pergunte ao FixBot
    Comentar
  14. LG Optimus F3 Charging port unit  Replacement: passo 14, imagem 1 %32
    • Use the plastic opening tool to carefully remove the home button board. It is attached with double-sided tape.
    Pergunte ao FixBot
    Comentar
  15. LG Optimus F3 Charging port unit  Replacement: passo 15, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  16. LG Optimus F3 Charging port unit  Replacement: passo 16, imagem 1 %32
    • You are all set.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Jonathan Fang
Membro desde: 10/28/15
356 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-5, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-5, Miles Fall 2015
UMASSD-MILES-F15S1G5
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 29
Ao todo: 935
