Ir para o conteúdo principal
LG Optimus 3D MicroSD/SIM Card Board Replacement
O que você precisa
  1. LG Optimus 3D MicroSD/SIM Card Board Replacement, Back Cover Removal: passo 1, imagem 1 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, Back Cover Removal: passo 1, imagem 2 %32
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
    Pergunte ao FixBot
    Comentar
  2. LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: passo 2, imagem 1 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: passo 2, imagem 2 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, Battery Removal: passo 2, imagem 3 %32
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
    Pergunte ao FixBot
    Comentar
  3. LG Optimus 3D MicroSD/SIM Card Board Replacement, Screw Removal: passo 3, imagem 1 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, Screw Removal: passo 3, imagem 2 %32
    • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
    • 5.5mm length PH00 screws
    • 4mm length PH00 screws
    Pergunte ao FixBot
    Comentar
  4. LG Optimus 3D MicroSD/SIM Card Board Replacement, Bottom Cover Removal: passo 4, imagem 1 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, Bottom Cover Removal: passo 4, imagem 2 %32
    • Gently pull down on the bottom cover to remove it.
    Pergunte ao FixBot
    Comentar
  5. LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: passo 5, imagem 1 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: passo 5, imagem 2 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, Mid-Cover Bezel Removal: passo 5, imagem 3 %32
    • Using a plastic opening tool, gently pry around the perimeter of the device.
    • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
    • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
    Pergunte ao FixBot
    Comentar
  6. LG Optimus 3D MicroSD/SIM Card Board Replacement, Ribbon Cable Disconnection: passo 6, imagem 1 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, Ribbon Cable Disconnection: passo 6, imagem 2 %32
    • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
    Pergunte ao FixBot
    Comentar
  7. LG Optimus 3D MicroSD/SIM Card Board Replacement, Adhesive Loosening: passo 7, imagem 1 %32
    • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
    • Evenly heat the device in short intervals for about one minute.
    • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
    Pergunte ao FixBot
    Comentar
  8. LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: passo 8, imagem 1 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: passo 8, imagem 2 %32 LG Optimus 3D MicroSD/SIM Card Board Replacement, SD/SIM Card Board Removal: passo 8, imagem 3 %32
    • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
    • If the board is too difficult to separate than more heating may be required.
    Pergunte ao FixBot
    Comentar
Conclusão
Dale Pearson
Membro desde: 09/22/14
784 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 10-6, Brown Fall 2014 Membro de USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 49
Ao todo: 1,375
