Ir para o conteúdo principal
LG L1200 Inner LCD Screen Replacement
O que você precisa
  1. LG L1200 Inner LCD Screen Replacement, Inner LCD Screen: passo 1, imagem 1 %32
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
    Pergunte ao FixBot
    Comentar
  2. LG L1200 Inner LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
    Pergunte ao FixBot
    Comentar
  3. LG L1200 Inner LCD Screen Replacement: passo 3, imagem 1 %32
    • Using a T6 Torx screwdriver, remove all four screws.
    Pergunte ao FixBot
    Comentar
  4. LG L1200 Inner LCD Screen Replacement: passo 4, imagem 1 %32 LG L1200 Inner LCD Screen Replacement: passo 4, imagem 2 %32 LG L1200 Inner LCD Screen Replacement: passo 4, imagem 3 %32
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
    Pergunte ao FixBot
    Comentar
  5. LG L1200 Inner LCD Screen Replacement: passo 5, imagem 1 %32 LG L1200 Inner LCD Screen Replacement: passo 5, imagem 2 %32
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
    Pergunte ao FixBot
    Comentar
  6. LG L1200 Inner LCD Screen Replacement: passo 6, imagem 1 %32
    • Remove the tape from the bottom of the LCD screen.
    Pergunte ao FixBot
    Comentar
  7. LG L1200 Inner LCD Screen Replacement: passo 7, imagem 1 %32 LG L1200 Inner LCD Screen Replacement: passo 7, imagem 2 %32 LG L1200 Inner LCD Screen Replacement: passo 7, imagem 3 %32
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
    Pergunte ao FixBot
    Comentar
  8. LG L1200 Inner LCD Screen Replacement: passo 8, imagem 1 %32 LG L1200 Inner LCD Screen Replacement: passo 8, imagem 2 %32 LG L1200 Inner LCD Screen Replacement: passo 8, imagem 3 %32
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
    Pergunte ao FixBot
    Comentar
  9. LG L1200 Inner LCD Screen Replacement: passo 9, imagem 1 %32 LG L1200 Inner LCD Screen Replacement: passo 9, imagem 2 %32
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
    Pergunte ao FixBot
    Comentar
  10. LG L1200 Inner LCD Screen Replacement: passo 10, imagem 1 %32 LG L1200 Inner LCD Screen Replacement: passo 10, imagem 2 %32
    • Use the spudger to remove the LCD screen from its backing.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 6-14, Maness Spring 2010 Membro de Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 2,562
