Ir para o conteúdo principal
LG K7 T-Mobile Rear Phone Camera Replacement
O que você precisa
  1. LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: passo 1, imagem 1 %32 LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: passo 1, imagem 2 %32
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
    Pergunte ao FixBot
    Comentar
  2. LG K7 T-Mobile Rear Phone  Camera Replacement: passo 2, imagem 1 %32
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
    Pergunte ao FixBot
    Comentar
  3. LG K7 T-Mobile Rear Phone  Camera Replacement: passo 3, imagem 1 %32
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  4. LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: passo 4, imagem 1 %32 LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: passo 4, imagem 2 %32
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
    Pergunte ao FixBot
    Comentar
  5. LG K7 T-Mobile Rear Phone  Camera Replacement: passo 5, imagem 1 %32 LG K7 T-Mobile Rear Phone  Camera Replacement: passo 5, imagem 2 %32 LG K7 T-Mobile Rear Phone  Camera Replacement: passo 5, imagem 3 %32
    • Turn the phone over so the screen is facing up
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
    Pergunte ao FixBot
    Comentar
  6. LG K7 T-Mobile Rear Phone  Camera Replacement: passo 6, imagem 1 %32 LG K7 T-Mobile Rear Phone  Camera Replacement: passo 6, imagem 2 %32 LG K7 T-Mobile Rear Phone  Camera Replacement: passo 6, imagem 3 %32
    • Locate the ribbon cable that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Salem Jean
Membro desde: 09/28/17
216 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S2-G5, Nance Fall 2017 Membro de USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 27
Ao todo: 800
