Ir para o conteúdo principal
LG Intuition Power Button Replacement
O que você precisa
  1. LG Intuition Power Button Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device so the two bottom screws are shown.
    Pergunte ao FixBot
    Comentar
  2. LG Intuition Power Button Replacement: passo 2, imagem 1 %32
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
    Pergunte ao FixBot
    Comentar
  3. LG Intuition Power Button Replacement: passo 3, imagem 1 %32
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
    Pergunte ao FixBot
    Comentar
  4. LG Intuition Power Button Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
    Pergunte ao FixBot
    Comentar
  5. LG Intuition Power Button Replacement: passo 5, imagem 1 %32
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
    Pergunte ao FixBot
    Comentar
  6. LG Intuition Power Button Replacement: passo 6, imagem 1 %32 LG Intuition Power Button Replacement: passo 6, imagem 2 %32
    • Gently raise the battery from its compartment.
    Pergunte ao FixBot
    Comentar
  7. LG Intuition Power Button Replacement, Plastic Motherboard Shield: passo 7, imagem 1 %32
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. LG Intuition Power Button Replacement: passo 8, imagem 1 %32
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
    Pergunte ao FixBot
    Comentar
  9. LG Intuition Power Button Replacement, Camera: passo 9, imagem 1 %32
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
    Pergunte ao FixBot
    Comentar
  10. LG Intuition Power Button Replacement: passo 10, imagem 1 %32
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
    Pergunte ao FixBot
    Comentar
  11. LG Intuition Power Button Replacement, Volume Buttons: passo 11, imagem 1 %32 LG Intuition Power Button Replacement, Volume Buttons: passo 11, imagem 2 %32
    • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
    Pergunte ao FixBot
    Comentar
  12. LG Intuition Power Button Replacement, Screen Protector: passo 12, imagem 1 %32 LG Intuition Power Button Replacement, Screen Protector: passo 12, imagem 2 %32
    • Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
    • Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
    Pergunte ao FixBot
    Comentar
  13. LG Intuition Power Button Replacement: passo 13, imagem 1 %32 LG Intuition Power Button Replacement: passo 13, imagem 2 %32
    • Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
    • Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
    Pergunte ao FixBot
    Comentar
  14. LG Intuition Power Button Replacement: passo 14, imagem 1 %32
    • Carefully use the plastic opening tool to pry the motherboard from the front screen.
    Pergunte ao FixBot
    Comentar
  15. LG Intuition Power Button Replacement: passo 15, imagem 1 %32 LG Intuition Power Button Replacement: passo 15, imagem 2 %32
    • Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
    • Remove the 5mm Phillips #00 screw on the top right of the phone.
    Pergunte ao FixBot
    Comentar
  16. LG Intuition Power Button Replacement: passo 16, imagem 1 %32
    • Carefully pull the ribbon cable upward and away from the front screen display.
    Pergunte ao FixBot
    Comentar
  17. LG Intuition Power Button Replacement: passo 17, imagem 1 %32
    • Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
    Pergunte ao FixBot
    Comentar
  18. LG Intuition Power Button Replacement: passo 18, imagem 1 %32 LG Intuition Power Button Replacement: passo 18, imagem 2 %32
    • Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
    Pergunte ao FixBot
    Comentar
  19. LG Intuition Power Button Replacement, Power Button: passo 19, imagem 1 %32
    • Slowly separate the power button from the screen display. This will release the power button.
    Pergunte ao FixBot
    Comentar
Conclusão
Thomas Morrissey
Membro desde: 10/25/18
616 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S3-G4, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G4, Peak Fall 2018
UMASSD-PEAK-F18S3G4
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 700
