Ir para o conteúdo principal
LG G8 ThinQ Speaker System Replacement
O que você precisa
  1. LG G8 ThinQ Speaker System Replacement, SIM Card Tray: passo 1, imagem 1 %32 LG G8 ThinQ Speaker System Replacement, SIM Card Tray: passo 1, imagem 2 %32 LG G8 ThinQ Speaker System Replacement, SIM Card Tray: passo 1, imagem 3 %32
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Speaker System Replacement, Back Panel: passo 2, imagem 1 %32 LG G8 ThinQ Speaker System Replacement, Back Panel: passo 2, imagem 2 %32 LG G8 ThinQ Speaker System Replacement, Back Panel: passo 2, imagem 3 %32
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Speaker System Replacement, Midframe: passo 3, imagem 1 %32 LG G8 ThinQ Speaker System Replacement, Midframe: passo 3, imagem 2 %32 LG G8 ThinQ Speaker System Replacement, Midframe: passo 3, imagem 3 %32
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Speaker System Replacement, Speaker System: passo 4, imagem 1 %32 LG G8 ThinQ Speaker System Replacement, Speaker System: passo 4, imagem 2 %32 LG G8 ThinQ Speaker System Replacement, Speaker System: passo 4, imagem 3 %32
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 595
