Ir para o conteúdo principal
LG G7 ThinQ Speaker System Replacement
O que você precisa
  1. LG G7 ThinQ Speaker System Replacement, SIM Card: passo 1, imagem 1 %32
    • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
    • After the SIM card tray is ejected, remove the SIM card tray from the phone.
    • Remove the SIM card from the tray.
  2. LG G7 ThinQ Speaker System Replacement, Back Cover: passo 2, imagem 1 %32
    • Place the phone so the back cover is facing upwards.
    • Insert the opening picks one by one onto each side with equal pressure.
    • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
    • If the picks are too thick to fit in, you can use the Jimmy to start the process.
    • Use the pick with the best leverage to pry the back cover away from the phone.
  3. LG G7 ThinQ Speaker System Replacement, Speaker System: passo 3, imagem 1 %32
    • This device did not come with a midframe, but if yours does, follow the instructions in the teardown video to remove it.
    • Remove the screws along the perimeter and central area of the phone using a Phillips #000 screwdriver.
  4. LG G7 ThinQ Speaker System Replacement, Remove the speaker system: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use your fingers or tweezers to remove the speaker system.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 812
