Ir para o conteúdo principal
LG G6 USB-C Port Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. LG G6 USB-C Port Replacement, iOpener Heating: passo 1, imagem 1 %32 LG G6 USB-C Port Replacement, iOpener Heating: passo 1, imagem 2 %32
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    Pergunte ao FixBot
    Comentar
  2. LG G6 USB-C Port Replacement: passo 2, imagem 1 %32
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    Pergunte ao FixBot
    Comentar
  3. LG G6 USB-C Port Replacement: passo 3, imagem 1 %32
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Pergunte ao FixBot
    Comentar
  4. LG G6 USB-C Port Replacement, Alternate iOpener heating method: passo 4, imagem 1 %32 LG G6 USB-C Port Replacement, Alternate iOpener heating method: passo 4, imagem 2 %32
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    Pergunte ao FixBot
    Comentar
  5. LG G6 USB-C Port Replacement, Battery: passo 5, imagem 1 %32
    • Apply the heated iOpener to the edge of the phone for about 2 minutes.
    Pergunte ao FixBot
    Comentar
  6. LG G6 USB-C Port Replacement: passo 6, imagem 1 %32 LG G6 USB-C Port Replacement: passo 6, imagem 2 %32 LG G6 USB-C Port Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
    • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
    • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
    Pergunte ao FixBot
    Comentar
  7. LG G6 USB-C Port Replacement: passo 7, imagem 1 %32 LG G6 USB-C Port Replacement: passo 7, imagem 2 %32
    • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
    Pergunte ao FixBot
    Comentar
  8. LG G6 USB-C Port Replacement: passo 8, imagem 1 %32 LG G6 USB-C Port Replacement: passo 8, imagem 2 %32
    • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
    Pergunte ao FixBot
    Comentar
  9. LG G6 USB-C Port Replacement: passo 9, imagem 1 %32
    • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
    Pergunte ao FixBot
    Comentar
  10. LG G6 USB-C Port Replacement: passo 10, imagem 1 %32 LG G6 USB-C Port Replacement: passo 10, imagem 2 %32 LG G6 USB-C Port Replacement: passo 10, imagem 3 %32
    • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
    • Do not use a knife as you may pierce the battery.
    Pergunte ao FixBot
    Comentar
  11. LG G6 USB-C Port Replacement, Motherboard: passo 11, imagem 1 %32 LG G6 USB-C Port Replacement, Motherboard: passo 11, imagem 2 %32
    • Locate the sim card tray release mechanism on the right edge.
    • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
    Pergunte ao FixBot
    Comentar
  12. LG G6 USB-C Port Replacement: passo 12, imagem 1 %32 LG G6 USB-C Port Replacement: passo 12, imagem 2 %32 LG G6 USB-C Port Replacement: passo 12, imagem 3 %32
    • Gently pry off the two connectors at the bottom of the phone.
    • Pry off the tape covering the vibrator.
    Pergunte ao FixBot
    Comentar
  13. LG G6 USB-C Port Replacement: passo 13, imagem 1 %32 LG G6 USB-C Port Replacement: passo 13, imagem 2 %32
    • The motherboard is now removable by gently lifting.
    • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
    Pergunte ao FixBot
    Comentar
  14. LG G6 USB-C Port Replacement, USB-C Port: passo 14, imagem 1 %32 LG G6 USB-C Port Replacement, USB-C Port: passo 14, imagem 2 %32
    • Gently pry the USB-c port assembly out of the frame.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
David Pugliese
Membro desde: 09/26/17
1.156 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S2-G6, Passmore Fall 2017 Membro de USF Tampa, Team S2-G6, Passmore Fall 2017
USFT-PASSMORE-F17S2G6
4 Membros
Autoria de 16 guias
2Comentários do guia
what size tape did you use?
Miguel “CharlieMike” Dias - Responder Compartilhar
I skipped removing the main board and was able to remove the port by just lifting the PCB up a little. I also did not remove the battery. just disconnected it. was able the slide out and in the USB port with no trouble or damage.
tenchi50 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 57
Ao todo: 10,098
