Ir para o conteúdo principal
LG G6 Battery Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. LG G6 Battery Replacement, iOpener Heating: passo 1, imagem 1 %32 LG G6 Battery Replacement, iOpener Heating: passo 1, imagem 2 %32
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    Pergunte ao FixBot
    Comentar
  2. LG G6 Battery Replacement: passo 2, imagem 1 %32
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    Pergunte ao FixBot
    Comentar
  3. LG G6 Battery Replacement: passo 3, imagem 1 %32
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Pergunte ao FixBot
    Comentar
  4. LG G6 Battery Replacement, Alternate iOpener heating method: passo 4, imagem 1 %32 LG G6 Battery Replacement, Alternate iOpener heating method: passo 4, imagem 2 %32
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    Pergunte ao FixBot
    Comentar
  5. LG G6 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Apply the heated iOpener to the edge of the phone for about 2 minutes.
    Pergunte ao FixBot
    Comentar
  6. LG G6 Battery Replacement: passo 6, imagem 1 %32 LG G6 Battery Replacement: passo 6, imagem 2 %32 LG G6 Battery Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
    • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
    • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
    Pergunte ao FixBot
    Comentar
  7. LG G6 Battery Replacement: passo 7, imagem 1 %32 LG G6 Battery Replacement: passo 7, imagem 2 %32
    • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
    Pergunte ao FixBot
    Comentar
  8. LG G6 Battery Replacement: passo 8, imagem 1 %32 LG G6 Battery Replacement: passo 8, imagem 2 %32
    • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
    Pergunte ao FixBot
    Comentar
  9. LG G6 Battery Replacement: passo 9, imagem 1 %32
    • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
    Pergunte ao FixBot
    Comentar
  10. LG G6 Battery Replacement: passo 10, imagem 1 %32 LG G6 Battery Replacement: passo 10, imagem 2 %32 LG G6 Battery Replacement: passo 10, imagem 3 %32
    • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
    • Do not use a knife as you may pierce the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
14 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S2-G6, Passmore Fall 2017 Membro de USF Tampa, Team S2-G6, Passmore Fall 2017
USFT-PASSMORE-F17S2G6
4 Membros
Autoria de 16 guias
7Comentários do guia
I found this article while searching for info on battery replacement. I’m considering purchasing this phone. I’m wondering if opening the back would wreck the waterproof rating.
brysonsemail - Responder Compartilhar
Yes, opening the back does remove the water sealant that is factory installed. You might be able to find the replacement “glue” that gives the phone the water proof rating but I’m not sure I would really trust it. Probably easier to just be really careful near liquids after the battery replacement. I’m looking at battery replacement in the next few months and that is my plan anyway, just keep the phone away from liquids like I’ve always tried to do with every phone I’ve owned.
Andrew McLendon - Responder Compartilhar
Will this require new adhesive to put the back back on?
Gage Cook - Responder Compartilhar
I also need to know.
Albert Einstein - Responder Compartilhar
I replaced the thermal paste, battery, USB port, and sim card tray. The Sim tray broke internally upon removal. Hopefully no pins were bent in the process. Everything else went together pretty well. The rear adhesive may be reusable but I would not recommend it. The precut adhesive I used I am not fond of and may have to redo the seal with some double-sided tape.
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 57
Ao todo: 26,368
