Ir para o conteúdo principal
LG G5 Battery Replacement
O que você precisa
  1. LG G5 Battery Replacement, Battery: passo 1, imagem 1 %32 LG G5 Battery Replacement, Battery: passo 1, imagem 2 %32 LG G5 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
    Pergunte ao FixBot
    Comentar
  2. LG G5 Battery Replacement: passo 2, imagem 1 %32 LG G5 Battery Replacement: passo 2, imagem 2 %32
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
    Pergunte ao FixBot
    Comentar
Conclusão
22 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
477.549 Reputação
Autoria de 538 guias
4Comentários do guia
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Responder Compartilhar
Was machen wenn Akku Snap In ab ist?
Ra Ku - Responder Compartilhar
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 66
Últimos 30 dias: 136
Ao todo: 17,653
