Ir para o conteúdo principal
LG G3 Vigor Display Assembly Replacement
O que você precisa
  1. LG G3 Vigor Display Assembly Replacement, Rear Case: passo 1, imagem 1 %32
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Display Assembly Replacement: passo 2, imagem 1 %32
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Display Assembly Replacement, Battery: passo 3, imagem 1 %32
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Display Assembly Replacement, Midframe: passo 4, imagem 1 %32
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Display Assembly Replacement: passo 5, imagem 1 %32 LG G3 Vigor Display Assembly Replacement: passo 5, imagem 2 %32 LG G3 Vigor Display Assembly Replacement: passo 5, imagem 3 %32
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Display Assembly Replacement, Rear Facing Camera: passo 6, imagem 1 %32
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Display Assembly Replacement, Front Facing Camera: passo 7, imagem 1 %32 LG G3 Vigor Display Assembly Replacement, Front Facing Camera: passo 7, imagem 2 %32
    • Remove the front camera.
  8. LG G3 Vigor Display Assembly Replacement, Motherboard: passo 8, imagem 1 %32
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Display Assembly Replacement: passo 9, imagem 1 %32 LG G3 Vigor Display Assembly Replacement: passo 9, imagem 2 %32
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Display Assembly Replacement, Vibration Motor: passo 10, imagem 1 %32
    • Use a spudger to remove the vibration motor.
    • It may have some slight adhesive, so some force may be necessary.
  11. LG G3 Vigor Display Assembly Replacement, Earpiece Speaker: passo 11, imagem 1 %32
    • Remove the earpiece speaker with the metal spudger by prying it out.
  12. LG G3 Vigor Display Assembly Replacement, Headphone Jack: passo 12, imagem 1 %32
    • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
  13. LG G3 Vigor Display Assembly Replacement, Display Assembly: passo 13, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers peel back the glued down ribbon cable at the bottom of the phone.
  14. LG G3 Vigor Display Assembly Replacement: passo 14, imagem 1 %32
    • Using a heat gun or the iFixit iOpener tool heat up the edges of the devices screen.
    • After a few minutes heating up the edges of the screen use a metal spudger tool or any other flat tool to dig under the edge of the screen.
    • Once under the edge of the screen work your way around the entire perimeter of the screen and pull the screen off.
  15. LG G3 Vigor Display Assembly Replacement: passo 15, imagem 1 %32
    • Once the screen has come off pull the ribbon cables through the hole and remove the screen completely.
Conclusão
6 outras pessoas executaram este guia.
Zhong Zhen
Membro desde: 02/10/16
675 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 12-5, Eyestone Spring 2016 Membro de USF Tampa, Team 12-5, Eyestone Spring 2016
USFT-EYESTONE-S16S12G5
4 Membros
Autoria de 5 guias
2Comentários do guia
i tried to replace the glass, the phone is now stuck at boot screen. the os would load occasionally before. possible battery/water problem. are there any hardware issue that would cause the boot screen (blinking red light)
Ryan Fukushima - Responder
Would anyone know a place to source the glass/lcd assembly. Mucho thanks!
Christopher Obidniak - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 2,220
