Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace or remove the motherboard in the LG G3 (D855).
O que você precisa
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
4 outras pessoas executaram este guia.
