Ir para o conteúdo principal
LG G Watch Spring Bar Pin Replacement
O que você precisa
  1. LG G Watch Spring Bar Pin Replacement, Wristband: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
    Pergunte ao FixBot
    Comentar
  2. LG G Watch Spring Bar Pin Replacement: passo 2, imagem 1 %32 LG G Watch Spring Bar Pin Replacement: passo 2, imagem 2 %32
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
    Pergunte ao FixBot
    Comentar
  3. LG G Watch Spring Bar Pin Replacement, Spring Bar Pin: passo 3, imagem 1 %32
    • Slide the spring bar pin out of the wristband.
    • Repeat this step for the other wristband.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Geoff Wacker
Membro desde: 09/30/13
92.869 Reputação
Autoria de 89 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 39
Ao todo: 1,344
