Ir para o conteúdo principal
LG G Watch R Power Button
O que você precisa
    1. LG G Watch R Power Button, Back Case: passo 1, imagem 1 %32 LG G Watch R Power Button, Back Case: passo 1, imagem 2 %32
      • Power off your watch before disassembling it.
      • Place the watch upside down on a hard surface so that its back case is facing upright.
      • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
      Pergunte ao FixBot
      Comentar
    2. LG G Watch R Power Button: passo 2, imagem 1 %32
      • Use a plastic opening tool to pry open the back case from both sides of the watch.
      Pergunte ao FixBot
      Comentar
    3. LG G Watch R Power Button: passo 3, imagem 1 %32
      • Remove the back case.
      Pergunte ao FixBot
      Comentar
    1. LG G Watch R Power Button, Motherboard: passo 4, imagem 1 %32 LG G Watch R Power Button, Motherboard: passo 4, imagem 2 %32
      • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
      Pergunte ao FixBot
      Comentar
    2. LG G Watch R Power Button: passo 5, imagem 1 %32 LG G Watch R Power Button: passo 5, imagem 2 %32
      • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. LG G Watch R Power Button: passo 6, imagem 1 %32
      • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
      Pergunte ao FixBot
      Comentar
    1. LG G Watch R Power Button, Battery Replacement: passo 7, imagem 1 %32
      • Use a plastic opening tool to pry the battery out of the device.
      • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
      Pergunte ao FixBot
      Comentar
    1. LG G Watch R Power Button, Battery Housing Replacement: passo 8, imagem 1 %32 LG G Watch R Power Button, Battery Housing Replacement: passo 8, imagem 2 %32
      • Pry the battery housing from the top right corner using a spudger.
      • Once loosened, remove the battery housing.
      Pergunte ao FixBot
      Comentar
    1. LG G Watch R Power Button, Power Button: passo 9, imagem 1 %32 LG G Watch R Power Button, Power Button: passo 9, imagem 2 %32 LG G Watch R Power Button, Power Button: passo 9, imagem 3 %32
      Ferramenta utilizada neste passo:
      • On the power button, locate a small grey washer on the interior side of the watch.
      • Use a pair of tweezers or another pointed object to push the washer out of its socket, and remove the power button.
      Pergunte ao FixBot
      Comentar
Conclusão
7 outras pessoas executaram este guia.
Westley Courchene
Membro desde: 01/13/15
3.410 Reputação
Autoria de 14 guias
Equipe
USF Tampa, Team 1-1, Remmell Fall 2015 Membro de USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Membros
Autoria de 86 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 57
Ao todo: 3,200
