Ir para o conteúdo principal
LG G Watch R Motherboard Replacement
O que você precisa
  1. LG G Watch R Motherboard Replacement, Back Case: passo 1, imagem 1 %32 LG G Watch R Motherboard Replacement, Back Case: passo 1, imagem 2 %32
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Motherboard Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the back case.
  4. LG G Watch R Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 LG G Watch R Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Motherboard Replacement: passo 5, imagem 1 %32 LG G Watch R Motherboard Replacement: passo 5, imagem 2 %32
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Motherboard Replacement: passo 6, imagem 1 %32
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
Conclusão
3 outras pessoas executaram este guia.
Westley Courchene
Membro desde: 01/13/15
3.410 Reputação
Autoria de 14 guias
Equipe
USF Tampa, Team 1-1, Remmell Fall 2015 Membro de USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Membros
Autoria de 14 guias
3Comentários do guia
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - Responder Compartilhar
Where do I buy a replacement motherboard from??
Brandon Reznik - Responder Compartilhar
Did you ever find anywhere to order a replacement motherboard?
Robert Dye - Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 83
Ao todo: 3,839
