Ir para o conteúdo principal
LG G Watch R Battery Housing
O que você precisa
  1. LG G Watch R Battery Housing, Back Case: passo 1, imagem 1 %32 LG G Watch R Battery Housing, Back Case: passo 1, imagem 2 %32
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
    So i bought a torx t5…but it is tooo big. It must br torx t4
    Jetze Kooistra - Responder
    I think I have damaged one of the screw heads while trying to unscrew the back of the watch.
    I used the Torx T4… but the screw was covered in quite a bit of rust. Now the Torx T4 can’t get a grip.
    What should I do? (Can anything be done?)
    John Maher - Responder
    Yea take a tiny file or a tiny Dremel attachment and carve a flat head groove in the head just enough so where you can use a flat head to get it
    Andrew L rambeaut -
    Thank you for good instructions! Saved me for 300€ (don’t have to buy a new wacth) ?
    Ernst Kranke - Responder
  2. LG G Watch R Battery Housing: passo 2, imagem 1 %32
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Housing: passo 3, imagem 1 %32
    • Remove the back case.
  4. LG G Watch R Battery Housing, Motherboard: passo 4, imagem 1 %32 LG G Watch R Battery Housing, Motherboard: passo 4, imagem 2 %32
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
    Where do I buy the parts? I already have your tools.
    Marco Roman - Responder
  5. LG G Watch R Battery Housing: passo 5, imagem 1 %32 LG G Watch R Battery Housing: passo 5, imagem 2 %32
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
    Add colored markup to indicate location of the 3 screws.
    Patty Remmell - Responder
    I felt like my #00 driver fit slightly better for these screws, but it probably depends on which toolkit or bit set you have.
    J Suo - Responder
  6. LG G Watch R Battery Housing: passo 6, imagem 1 %32
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Housing, Battery Replacement: passo 7, imagem 1 %32
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
    Thanks this was very helpful.
    Oseghale Akhigbe - Responder
    Thanks for your instructions
    Gregory Francis - Responder
    Thank you for this guide!
    Стас Шишкин - Responder
  8. LG G Watch R Battery Housing, Battery Housing Replacement: passo 8, imagem 1 %32 LG G Watch R Battery Housing, Battery Housing Replacement: passo 8, imagem 2 %32
    • Pry the battery housing from the top right corner using a spudger.
    • Once loosened, remove the battery housing.
Conclusão
Westley Courchene
Membro desde: 01/13/15
3.410 Reputação
Autoria de 14 guias
Equipe
USF Tampa, Team 1-1, Remmell Fall 2015 Membro de USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
Membros da 5
Autoria de 14 guias
Um comentário
Hi there, do you know where can i buy the battery housing? Thank you..
Eugene Kang - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,594
