Ir para o conteúdo principal
LG G Vista Battery Replacement
  1. LG G Vista Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the device is powered off.
    Pergunte ao FixBot
    Comentar
  2. LG G Vista Battery Replacement: passo 2, imagem 1 %32
    • Remove the back cover by gently prying open the case of the device from the charging port.
    Pergunte ao FixBot
    Comentar
  3. LG G Vista Battery Replacement: passo 3, imagem 1 %32
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
Make sure battery is perfectly fitted into it's spot before replacing the back cover. Power phone on to ensure the new battery is working properly.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 1,073
