Ir para o conteúdo principal
LG G Pad 8.3 Volume Control Buttons Replacement
O que você precisa
  1. LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: passo 1, imagem 1 %32 LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: passo 1, imagem 2 %32
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Volume Control Buttons Replacement: passo 2, imagem 1 %32 LG G Pad 8.3 Volume Control Buttons Replacement: passo 2, imagem 2 %32 LG G Pad 8.3 Volume Control Buttons Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Volume Control Buttons Replacement: passo 3, imagem 1 %32 LG G Pad 8.3 Volume Control Buttons Replacement: passo 3, imagem 2 %32
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: passo 4, imagem 1 %32 LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: passo 4, imagem 2 %32
    • With the screen facing towards you and the top of the tablet towards your left, locate the volume buttons on the left side.
    • Using a spudger or your hands, remove the volume control buttons, which are attached with adhesive.
Conclusão
Mario Salguero
Membro desde: 09/14/15
781 Reputação
Autoria de 6 guias
Equipe
CSU Fullerton, Team 1-6, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,072
