Introdução
If your tablet isn't working properly, you may need to replace the motherboard. This guide will show you how to replace the motherboard.
O que você precisa
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
8 outras pessoas executaram este guia.
