Introdução
If your front facing camera is not working properly, it may be time to replace it. This guide will show you how to replace the front facing camera.
O que você precisa
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
Use a plastic opening tool to lift the front facing camera out of the device.
Uma outra pessoa concluiu este guia.
