Ir para o conteúdo principal
LG G Pad 8.3 Battery Replacement
O que você precisa
  1. LG G Pad 8.3 Battery Replacement, Back Panel: passo 1, imagem 1 %32 LG G Pad 8.3 Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Battery Replacement: passo 2, imagem 1 %32 LG G Pad 8.3 Battery Replacement: passo 2, imagem 2 %32 LG G Pad 8.3 Battery Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Battery Replacement: passo 3, imagem 1 %32 LG G Pad 8.3 Battery Replacement: passo 3, imagem 2 %32
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Battery Replacement, Speaker: passo 4, imagem 1 %32 LG G Pad 8.3 Battery Replacement, Speaker: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  5. LG G Pad 8.3 Battery Replacement: passo 5, imagem 1 %32
    • Use your fingers to remove the speaker.
  6. LG G Pad 8.3 Battery Replacement, Battery: passo 6, imagem 1 %32 LG G Pad 8.3 Battery Replacement, Battery: passo 6, imagem 2 %32
    • Remove the 3mm Phillips #000 screws from the corners of the battery.
  7. LG G Pad 8.3 Battery Replacement: passo 7, imagem 1 %32 LG G Pad 8.3 Battery Replacement: passo 7, imagem 2 %32 LG G Pad 8.3 Battery Replacement: passo 7, imagem 3 %32
    • Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
    • The cable is attached with an adhesive.
    • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
  8. LG G Pad 8.3 Battery Replacement: passo 8, imagem 1 %32 LG G Pad 8.3 Battery Replacement: passo 8, imagem 2 %32
    • Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
    • Remove the ribbon cable from the device.
  9. LG G Pad 8.3 Battery Replacement: passo 9, imagem 1 %32 LG G Pad 8.3 Battery Replacement: passo 9, imagem 2 %32
    • Unhook the battery from the top of the device.
Conclusão
18 outras pessoas executaram este guia.
Mario Salguero
Membro desde: 09/14/15
781 Reputação
Autoria de 6 guias
Equipe
CSU Fullerton, Team 1-6, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
Membros da 4
Autoria de 14 guias
9 comentários
Every teardown I can find on this tablet has that darn screw in the sd card slot, but mine does not!! Does ANYBODY have teardown for mine? I can send pics, it's Verizon Gpad 8.3 LTE, slot holds sd and sim but NO screw. Son spilled water on it so screen is all dark and haptic stays on, I'd like to attempt the rice trick if I can open it.
Wesley Krasko - Responder
The other models have a sponge adhesive on the back of the battery.
Completely disregard the first screw.
supramaster2099 -
Wesley - Me too. I have no idea why Android released two different models with the same freaking model name. I thought they had more common sense than that. If anyone has the teardown for the new model, holler.
Slavelike Constructs - Responder
Same here. No screw
jon - Responder
sorry this teardown is not for the 8.3
krackeddude - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 23
Últimos 30 dias: 66
Duração total: 44,283
