Ir para o conteúdo principal
LG Front Load Washing Machine Pump Assembly Replacement
O que você precisa
  1. LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: passo 1, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: passo 1, imagem 2 %32
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    Pergunte ao FixBot
    Comentar
  2. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: passo 2, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: passo 2, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: passo 2, imagem 3 %32
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    Pergunte ao FixBot
    Comentar
  3. LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: passo 3, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: passo 3, imagem 2 %32
    • Slide the top panel towards the rear of the device to disconnect its clips.
    Pergunte ao FixBot
    Comentar
  4. LG Front Load Washing Machine Pump Assembly Replacement: passo 4, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 4, imagem 2 %32
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    Pergunte ao FixBot
    Comentar
  5. LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: passo 5, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: passo 5, imagem 2 %32
    • Pull the detergent drawer away from the chassis as far as it will go.
    Pergunte ao FixBot
    Comentar
  6. LG Front Load Washing Machine Pump Assembly Replacement: passo 6, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 6, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 6, imagem 3 %32
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
    Pergunte ao FixBot
    Comentar
  7. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: passo 7, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: passo 7, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: passo 7, imagem 3 %32
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
    Pergunte ao FixBot
    Comentar
  8. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: passo 8, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: passo 8, imagem 2 %32
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
    Pergunte ao FixBot
    Comentar
  9. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the detergent dispenser: passo 9, imagem 1 %32
    • Remove the screw(s) securing the detergent dispenser.
    Pergunte ao FixBot
    Comentar
  10. LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: passo 10, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: passo 10, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: passo 10, imagem 3 %32
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
    Pergunte ao FixBot
    Comentar
  11. LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: passo 11, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: passo 11, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: passo 11, imagem 3 %32
    • Remove the control panel, making sure to thread any cables through the chassis.
    Pergunte ao FixBot
    Comentar
  12. LG Front Load Washing Machine Pump Assembly Replacement, Open the door: passo 12, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Open the door: passo 12, imagem 2 %32
    • Open the front door completely.
    Pergunte ao FixBot
    Comentar
  13. LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: passo 13, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: passo 13, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: passo 13, imagem 3 %32
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
    Pergunte ao FixBot
    Comentar
  14. LG Front Load Washing Machine Pump Assembly Replacement: passo 14, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 14, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 14, imagem 3 %32
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
    Pergunte ao FixBot
    Comentar
  15. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: passo 15, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: passo 15, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: passo 15, imagem 3 %32
    • Use your fingers to pull the boot off its lip on the front panel.
    Pergunte ao FixBot
    Comentar
  16. LG Front Load Washing Machine Pump Assembly Replacement: passo 16, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 16, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 16, imagem 3 %32
    • Slide your fingers around the lip of the boot until it's completely separated from the panel.
    Pergunte ao FixBot
    Comentar
  17. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: passo 17, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: passo 17, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: passo 17, imagem 3 %32
    • Open the filter panel at the bottom of the front panel.
    • Unclip the filter panel.
    Pergunte ao FixBot
    Comentar
  18. LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: passo 18, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: passo 18, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: passo 18, imagem 3 %32
    • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
    • Place a bowl next to the machine.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
    Pergunte ao FixBot
    Comentar
  19. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the filter trim: passo 19, imagem 1 %32
    • Remove the screw(s) securing the filter trim.
    Pergunte ao FixBot
    Comentar
  20. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: passo 20, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: passo 20, imagem 2 %32
    • Pull the filter trim straight off the front panel to remove it.
    Pergunte ao FixBot
    Comentar
  21. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the lower front panel: passo 21, imagem 1 %32
    • Remove the screw(s) securing the lower front panel.
    Pergunte ao FixBot
    Comentar
  22. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the door latch: passo 22, imagem 1 %32
    • Remove the screw(s) securing the door latch.
    Pergunte ao FixBot
    Comentar
  23. LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: passo 23, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: passo 23, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: passo 23, imagem 3 %32
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
    Pergunte ao FixBot
    Comentar
  24. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: passo 24, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: passo 24, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: passo 24, imagem 3 %32
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Remove the screw(s) securing the front panel.
    Pergunte ao FixBot
    Comentar
  25. LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: passo 25, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: passo 25, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: passo 25, imagem 3 %32
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
    Pergunte ao FixBot
    Comentar
  26. LG Front Load Washing Machine Pump Assembly Replacement: passo 26, imagem 1 %32
    • Remove the front panel.
    Pergunte ao FixBot
    Comentar
  27. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: passo 27, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: passo 27, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: passo 27, imagem 3 %32
    • Twist and remove the pump filter.
    Pergunte ao FixBot
    Comentar
  28. LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: passo 28, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: passo 28, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: passo 28, imagem 3 %32
    • Push the drain hose through its hole in the chassis until it's completely inside the device.
    Pergunte ao FixBot
    Comentar
  29. LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: passo 29, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: passo 29, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: passo 29, imagem 3 %32
    • Use diagonal cutters, or scissors, to remove any cable ties securing the plastic wrap on the pump assembly cable connector(s).
    Pergunte ao FixBot
    Comentar
  30. LG Front Load Washing Machine Pump Assembly Replacement: passo 30, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 30, imagem 2 %32
    • Fold the plastic wrap away from the cables, enough to expose the connector(s).
    • During reassembly, replace the cable ties to ensure a water-tight fit for the plastic wrap.
    Pergunte ao FixBot
    Comentar
  31. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: passo 31, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: passo 31, imagem 2 %32
    • Disconnect the connector(s) attached to the pump cable.
    Pergunte ao FixBot
    Comentar
  32. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: passo 32, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: passo 32, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: passo 32, imagem 3 %32
    • Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
    Pergunte ao FixBot
    Comentar
  33. LG Front Load Washing Machine Pump Assembly Replacement: passo 33, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 33, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement: passo 33, imagem 3 %32
    • Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
    • Pull the drain hose straight off its connection on the assembly.
    Pergunte ao FixBot
    Comentar
  34. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: passo 34, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: passo 34, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: passo 34, imagem 3 %32
    • Repeat the last two steps for the pump hose.
    Pergunte ao FixBot
    Comentar
  35. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: passo 35, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: passo 35, imagem 2 %32
    • Remove the screw(s) securing the pump assembly to the bottom lip of the washer.
    Pergunte ao FixBot
    Comentar
  36. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: passo 36, imagem 1 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: passo 36, imagem 2 %32 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: passo 36, imagem 3 %32
    • Lift the pump assembly out of its location in the frame to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
4 outras pessoas executaram este guia.
Bill Gilbert
Membro desde: 06/30/22
39.969 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.617 guias
2Comentários do guia
Hi Bill, Fantastic instructions - thanks for taking the time to put these together!
Ken Adams - Responder Compartilhar
Wow, that's intense. I wonder if I can just prop it up and get to that pump from the bottom? I don't have a jack stand or anything but I saw someone lean it back into a metal step stool.
Doyle Stadt - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 36
Últimos 30 dias: 180
Ao todo: 5,012
