Ir para o conteúdo principal
LG Front Load Washing Machine Inlet Valve Assembly Replacement
O que você precisa
  1. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: passo 1, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: passo 1, imagem 2 %32
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    Pergunte ao FixBot
    Comentar
  2. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: passo 2, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: passo 2, imagem 2 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: passo 2, imagem 3 %32
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    Pergunte ao FixBot
    Comentar
  3. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: passo 3, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: passo 3, imagem 2 %32
    • Slide the top panel towards the rear of the device to disconnect its clips.
    Pergunte ao FixBot
    Comentar
  4. LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 4, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 4, imagem 2 %32
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    Pergunte ao FixBot
    Comentar
  5. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: passo 5, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: passo 5, imagem 2 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: passo 5, imagem 3 %32
    • To prevent confusion, label each valve and its corresponding hose.
    • You can use masking tape or mark the components themselves.
    • Repeat the labelling procedure for each valve and its corresponding connector.
    Pergunte ao FixBot
    Comentar
  6. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: passo 6, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: passo 6, imagem 2 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: passo 6, imagem 3 %32
    • Disconnect the connectors from the inlet valve.
    • Always grip cables by their connectors and not the wires themselves.
    Pergunte ao FixBot
    Comentar
  7. LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 7, imagem 1 %32
    • Place a dry rag under the inlet valve to soak up any lingering water.
    Pergunte ao FixBot
    Comentar
  8. LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 8, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 8, imagem 2 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 8, imagem 3 %32
    • Use slip joint pliers to pinch the inlet valve hose clamp and pull it away from the inlet valve assembly.
    Pergunte ao FixBot
    Comentar
  9. LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 9, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 9, imagem 2 %32
    • Use slip joint pliers to rotate the inlet valve hose back and forth around its connection and loosen it.
    Pergunte ao FixBot
    Comentar
  10. LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 10, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 10, imagem 2 %32
    • Pull the inlet valve hose straight off its connection on the inlet valve assembly.
    Pergunte ao FixBot
    Comentar
  11. LG Front Load Washing Machine Inlet Valve Assembly Replacement: passo 11, imagem 1 %32
    • Repeat the previous three steps for each remaining hose attached to the inlet valve assembly.
    Pergunte ao FixBot
    Comentar
  12. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: passo 12, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: passo 12, imagem 2 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: passo 12, imagem 3 %32
    • If your replacement part comes with filters pre-installed, skip this step.
    • Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
    • Remove the filters.
    Pergunte ao FixBot
    Comentar
  13. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: passo 13, imagem 1 %32
    • Remove the screws securing the inlet valve assembly.
    Pergunte ao FixBot
    Comentar
  14. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: passo 14, imagem 1 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: passo 14, imagem 2 %32 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: passo 14, imagem 3 %32
    • Pull the inlet valve assembly straight out of its slot in the chassis to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
Bill Gilbert
Membro desde: 06/30/22
40.137 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.231 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 47
Últimos 30 dias: 197
Ao todo: 6,779
