Ir para o conteúdo principal
LG Front Load Washing Machine Drain Hose Replacement
O que você precisa
    1. LG Front Load Washing Machine Drain Hose Replacement, Safety Precautions: passo 1, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Safety Precautions: passo 1, imagem 2 %32
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Pergunte ao FixBot
      Comentar
    1. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the top panel: passo 2, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the top panel: passo 2, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the top panel: passo 2, imagem 3 %32
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Pergunte ao FixBot
      Comentar
    2. LG Front Load Washing Machine Drain Hose Replacement, Remove the top panel: passo 3, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the top panel: passo 3, imagem 2 %32
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Pergunte ao FixBot
      Comentar
    3. LG Front Load Washing Machine Drain Hose Replacement: passo 4, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 4, imagem 2 %32
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Pergunte ao FixBot
      Comentar
    1. LG Front Load Washing Machine Drain Hose Replacement, Remove the detergent drawer: passo 5, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the detergent drawer: passo 5, imagem 2 %32
      • Pull the detergent drawer away from the chassis as far as it will go.
      Pergunte ao FixBot
      Comentar
    2. LG Front Load Washing Machine Drain Hose Replacement: passo 6, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 6, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 6, imagem 3 %32
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Pergunte ao FixBot
      Comentar
    1. LG Front Load Washing Machine Drain Hose Replacement, Disconnect the control panel: passo 7, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the control panel: passo 7, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the control panel: passo 7, imagem 3 %32
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Pergunte ao FixBot
      Comentar
    2. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the control panel: passo 8, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the control panel: passo 8, imagem 2 %32
      • Remove the screw(s) securing the control panel to the top edge of the chassis.
      Pergunte ao FixBot
      Comentar
    3. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the detergent dispenser: passo 9, imagem 1 %32
      • Remove the screw(s) securing the detergent dispenser.
      Pergunte ao FixBot
      Comentar
    4. LG Front Load Washing Machine Drain Hose Replacement, Unclip the control panel: passo 10, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Unclip the control panel: passo 10, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Unclip the control panel: passo 10, imagem 3 %32
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      Pergunte ao FixBot
      Comentar
    5. LG Front Load Washing Machine Drain Hose Replacement, Remove the control panel: passo 11, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the control panel: passo 11, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the control panel: passo 11, imagem 3 %32
      • Remove the control panel, making sure to thread any cables through the chassis.
      Pergunte ao FixBot
      Comentar
    1. LG Front Load Washing Machine Drain Hose Replacement, Open the door: passo 12, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Open the door: passo 12, imagem 2 %32
      • Open the front door completely.
      Pergunte ao FixBot
      Comentar
    2. LG Front Load Washing Machine Drain Hose Replacement, Remove the boot ring: passo 13, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the boot ring: passo 13, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the boot ring: passo 13, imagem 3 %32
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Pergunte ao FixBot
      Comentar
    3. LG Front Load Washing Machine Drain Hose Replacement: passo 14, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 14, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 14, imagem 3 %32
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      Pergunte ao FixBot
      Comentar
    4. LG Front Load Washing Machine Drain Hose Replacement, Disconnect the boot: passo 15, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the boot: passo 15, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the boot: passo 15, imagem 3 %32
      • Use your fingers to pull the boot off its lip on the front panel.
      Pergunte ao FixBot
      Comentar
    5. LG Front Load Washing Machine Drain Hose Replacement: passo 16, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 16, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 16, imagem 3 %32
      • Slide your fingers around the lip of the boot until it's completely separated from the panel.
      Pergunte ao FixBot
      Comentar
    6. LG Front Load Washing Machine Drain Hose Replacement, Remove the filter panel: passo 17, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the filter panel: passo 17, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the filter panel: passo 17, imagem 3 %32
      • Open the filter panel at the bottom of the front panel.
      • Unclip the filter panel.
      Pergunte ao FixBot
      Comentar
    7. LG Front Load Washing Machine Drain Hose Replacement, Drain the machine: passo 18, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Drain the machine: passo 18, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Drain the machine: passo 18, imagem 3 %32
      • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
      • Place a bowl next to the machine.
      • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
      • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
      • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
      Pergunte ao FixBot
      Comentar
    8. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the filter trim: passo 19, imagem 1 %32
      • Remove the screw(s) securing the filter trim.
      Pergunte ao FixBot
      Comentar
    9. LG Front Load Washing Machine Drain Hose Replacement, Remove the filter trim: passo 20, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the filter trim: passo 20, imagem 2 %32
      • Pull the filter trim straight off the front panel to remove it.
      Pergunte ao FixBot
      Comentar
    10. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the lower front panel: passo 21, imagem 1 %32
      • Remove the screw(s) securing the lower front panel.
      Pergunte ao FixBot
      Comentar
    11. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the door latch: passo 22, imagem 1 %32
      • Remove the screw(s) securing the door latch.
      Pergunte ao FixBot
      Comentar
    12. LG Front Load Washing Machine Drain Hose Replacement, Remove the door latch: passo 23, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the door latch: passo 23, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the door latch: passo 23, imagem 3 %32
      • Pull the door latch through its slot in the chassis and let it hang on its wire.
      Pergunte ao FixBot
      Comentar
    13. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the front panel: passo 24, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the front panel: passo 24, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the front panel: passo 24, imagem 3 %32
      • Hold the front panel against the chassis while performing this step to prevent it from falling.
      • Remove the screw(s) securing the front panel.
      Pergunte ao FixBot
      Comentar
    14. LG Front Load Washing Machine Drain Hose Replacement, Remove the front panel: passo 25, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the front panel: passo 25, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the front panel: passo 25, imagem 3 %32
      • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
      • Pull the front panel away from the chassis to completely separate the front panel.
      Pergunte ao FixBot
      Comentar
    15. LG Front Load Washing Machine Drain Hose Replacement: passo 26, imagem 1 %32
      • Remove the front panel.
      Pergunte ao FixBot
      Comentar
    1. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the rear panel: passo 27, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the rear panel: passo 27, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Unfasten the rear panel: passo 27, imagem 3 %32
      • Remove the screw(s) securing the rear panel.
      Pergunte ao FixBot
      Comentar
    2. LG Front Load Washing Machine Drain Hose Replacement, Remove the rear panel: passo 28, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the rear panel: passo 28, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the rear panel: passo 28, imagem 3 %32
      • Unclip the rear panel from the chassis.
      Pergunte ao FixBot
      Comentar
    3. LG Front Load Washing Machine Drain Hose Replacement: passo 29, imagem 1 %32
      • Remove the rear panel.
      Pergunte ao FixBot
      Comentar
    1. LG Front Load Washing Machine Drain Hose Replacement, Disconnect the drain hose: passo 30, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the drain hose: passo 30, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Disconnect the drain hose: passo 30, imagem 3 %32
      • Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
      Pergunte ao FixBot
      Comentar
    2. LG Front Load Washing Machine Drain Hose Replacement: passo 31, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 31, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 31, imagem 3 %32
      • Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
      • Pull the drain hose straight off its connection on the assembly.
      Pergunte ao FixBot
      Comentar
    3. LG Front Load Washing Machine Drain Hose Replacement, Unclip the drain hose: passo 32, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Unclip the drain hose: passo 32, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Unclip the drain hose: passo 32, imagem 3 %32
      • Depending on your device, your drain hose could be clipped to different sides of the chassis.
      • While holding the back of clip with one hand, use the other to push the prongs of the clip and release them.
      • Repeat for each prong until the clip slides through the chassis.
      Pergunte ao FixBot
      Comentar
    4. LG Front Load Washing Machine Drain Hose Replacement, Reposition the drain hose: passo 33, imagem 1 %32
      • Reposition the drain hose so you can access the plastic clip.
      Pergunte ao FixBot
      Comentar
    5. LG Front Load Washing Machine Drain Hose Replacement, Unfasten the drain hose: passo 34, imagem 1 %32
      • Remove the screw(s) securing the drain hose.
      Pergunte ao FixBot
      Comentar
    6. LG Front Load Washing Machine Drain Hose Replacement, Apply the tape: passo 35, imagem 1 %32
      • To prevent confusion during reassembly, apply some masking tape where the plastic clip is located.
      Pergunte ao FixBot
      Comentar
    7. LG Front Load Washing Machine Drain Hose Replacement, Remove the plastic clip: passo 36, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the plastic clip: passo 36, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the plastic clip: passo 36, imagem 3 %32
      • Pull the plastic clip off the drain hose.
      • Remove the plastic clip.
      Pergunte ao FixBot
      Comentar
    8. LG Front Load Washing Machine Drain Hose Replacement, Remove the drain hose: passo 37, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement, Remove the drain hose: passo 37, imagem 2 %32
      • Pull the drain hose through its slot in the chassis.
      Pergunte ao FixBot
      Comentar
    9. LG Front Load Washing Machine Drain Hose Replacement: passo 38, imagem 1 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 38, imagem 2 %32 LG Front Load Washing Machine Drain Hose Replacement: passo 38, imagem 3 %32
      • Remove the drain hose.
      Pergunte ao FixBot
      Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
3 outras pessoas executaram este guia.
Bill Gilbert
Membro desde: 06/30/22
40.168 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 49.851 guias
11Comentários do guia
My washer still has water in can I start from step 26, to get the drain hose out?
Tan - Responder Compartilhar
Hello! You need the water out, but you can try to drain it by lowering the drain hose to floor level with a pan or shallow bowl to catch water from the end of it. If your drain hose is the problem (like it is plugged or kinked), this probably won't work. A fast but messy way to drain the washer is to remove the coin trap/filter basket located at the front of the machine (see step 18 the large round black cap is what you remove). Have a lot of towels on hand to absorb the water. If you want to you can use the small drain hose that is next to the filter. Have a bowl or container on hand to catch the water. pull the small plug out from the end of the little hose and water will start draining. It will be slow but a lot less messy.
Bill Gilbert - Responder Compartilhar
I just added a step to show how to drain the machine (it is a new Step 18 in the guide)
Is there a check valve located inside this hose?
Kerri V - Responder Compartilhar
I just need to check the drain hose for a clog. Is there a way to disconnect the drain hose without disassembling the machine so much? or, can I disconnect the drain hose after removing the rear panel?
Ryan D Whitaker - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 20
Últimos 7 dias: 203
Últimos 30 dias: 899
Ao todo: 34,468
