Ir para o conteúdo principal
LG Flatron W2241S Capacitors Replacement
O que você precisa
  1. LG Flatron W2241S Capacitors Replacement, Opening the monitor: passo 1, imagem 1 %32 LG Flatron W2241S Capacitors Replacement, Opening the monitor: passo 1, imagem 2 %32
    • Use a spudger to remove the plastic basel around the display and remove any screws that you see on the back.
    • Carefully lift up the display assembly and set it aside.
  2. LG Flatron W2241S Capacitors Replacement, Reaching the main board: passo 2, imagem 1 %32 LG Flatron W2241S Capacitors Replacement, Reaching the main board: passo 2, imagem 2 %32 LG Flatron W2241S Capacitors Replacement, Reaching the main board: passo 2, imagem 3 %32
    • Lift up the metal bracket and carefully remove all connectors
  3. LG Flatron W2241S Capacitors Replacement, Finding the capacitors: passo 3, imagem 1 %32 LG Flatron W2241S Capacitors Replacement, Finding the capacitors: passo 3, imagem 2 %32
    • After you flip the metal bracket, it should look something like this.
    • Identify the faulty capacitors, remove them and solder new ones.
    • In my case, those marked in blue were busted and prevented the monitor from working.
    • For good measure I replaced all of them with brand new ones. It is a good idea that you do too.
Conclusão
6 outras pessoas executaram este guia.
Simeon Brankov
Membro desde: 11/08/20
7.279 Reputação
Autoria de 54 guias
4Comentários do guia
This repair guide helped me fix my LG Flatron W2242T 22" computer monitor that powered off but would not power back on.
After making the repair, replacing bulging capacitors C203, C204, C205, and C212 with replacements of the same value, the monitor powered back on and works again!
richguard - Responder
Hello,
I am very glad to hear that my guide helped you!
Simeon Brankov -
Here I am using this in 2024. Worked great! The screw less enclosure threw me off.
Jon - Responder
Necesito reparar el apagado del reflector trasero, se apaga cuando quiere y hay que esperar de cinco a diez minutos para encenderlo de nuevo con el encendido del monitor, es muy molesto, ahora tiene un problema nuevo, la pantalla se divide en dos tonos diferentes, el flatron es el W2043S
Carlos David Correa Santillan - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 74
Ao todo: 1,686
